Old 06-18-2014, 02:49 PM   #1
koukizhang
koukizhang's Avatar
koukizhang is on a distinguished road
S14 KA24DE High Idle
Hi I'm kind of new to this and am not very mechanically familiar. I have a 1995 240sx s14 with a rebuilt ka24de that idles around 2000 - 3000 rpm's. I'm not sure if it's a vacuum leak or I need to adjust the IACV, but I need some suggestions to where I should start. Thanks
koukizhang is offline   Reply With Quote
Old 06-23-2014, 03:59 PM   #2
koukizhang
koukizhang's Avatar
so... no one has any ideas???
Old 06-23-2014, 07:38 PM   #3
cotbu
cotbu's Avatar
High uncontrollable idle, adjusting the idle air control valve has no effect on idle.
Usually a person didn't connect the coolant lines to the iacv, or vacuum leak(big for 2-3krpm) or it could be the TPS closed voltage is wrong.
Old 06-24-2014, 12:40 PM   #4
koukizhang
koukizhang's Avatar
I'll check the coolant lines and TPS fist then, thanks
Old 06-27-2014, 08:44 AM   #5
goldens14
goldens14's Avatar
goldens14 is an unknown quantity at this point
And have you adjusted your idle down, there's a Philips head slot you can twist thay will adjust the idle its on the passenger side (on the firewall side of the intake manifold)
goldens14 is offline   Reply With Quote
Old 12-07-2014, 06:36 PM   #6
trikk
trikk's Avatar
trikk is an unknown quantity at this point
did you get it fixed?
trikk is offline   Reply With Quote
Old 12-08-2014, 09:18 PM   #7
koukizhang
koukizhang's Avatar
Yeah. I adjusted the idle down, bought a new maf sensor, and fixed a small vacuum leak. Not sure which one did the trick but she idles perfectly now.
240sx, idle, ka24de, s14, zenki
