Old 06-07-2014, 01:34 PM   #1
914Slide
914Slide's Avatar
914Slide can only hope to improve
CA New to Ca18det Quick Question
okay so i got this car with this cheap boost controller already in the car and i just what to get it back to stock form.
It is running like this. a nipple from the compressor side of the turbo then a long skinny line up to the controller, then out the other side of the controller down to the waste gate.
I was told i can just run a line from that nipple to the waste gate?
914Slide is offline   Reply With Quote
Old 06-08-2014, 09:49 AM   #2
Croustibat
Yes.
/msglength
Old 06-08-2014, 04:35 PM   #3
914Slide
914Slide's Avatar
CA
Originally Posted by Croustibat View Post
Yes.
/msglength
thanks man its like a 4 in line from compressor housing to the wastgate
Old 06-09-2014, 07:13 AM   #4
Croustibat
Sorry, maybe it is because english is not my native language, but i don't understand what you posted there.
The original way it is set is with the compression nipple directly connected to the wastegate actuator like this (this is not your turbo but that is how it is on every turbo)
When you have a boost controler, it needs to have an actuator placed between the 2, as it creates a regulated leak to the actuator command to add boost.
Old 06-14-2014, 10:51 PM   #5
914Slide
914Slide's Avatar
CA ca18det boost
Yes thank you
this is all i needed
boost, ca18det, controller, vaccum
