Old 06-02-2014, 09:05 AM   #1
yardy
yardy's Avatar
yardy is an unknown quantity at this point
Bad Idling on 95 KA motor
I installed a 95 KA in my 93 hatck back in 2011 and drove it from FL to MO. In 2012 I blew a head gasket and I figure the cause was not torquing the head bolts after the 500 miles ( trip was 723m) I replaced the gasket in summer 2012 but it never started and since I was leaving in a couple months I just stored it.
When I returned 2013 I adjusted the timing and it started right up, but has been idling bad ever since. Here is a vid of it;
http://youtu.be/GchBQULhaeI
I think the timing might be off a little still or there is a huge vac leak under the intake but cannot pi point the location, any help you can give would help guys, thanks in advance.
yardy is offline   Reply With Quote
Old 06-03-2014, 09:32 AM   #2
yardy
yardy's Avatar
36 views and no suggestions guys, please help me out here, I would like to drive it at least once in the warm weather.
Old 06-03-2014, 10:17 PM   #3
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
I can't hear anything over whatever that massive whooshing sound is.. Your timing is probably off though
pacotaco345 is offline   Reply With Quote
Old 06-04-2014, 09:32 AM   #4
yardy
yardy's Avatar
That massive whooshing sound is air, which is why I think there is a bad vaccum leak. I timed everything according to the FSM and even tried a light. It satrts perfectly but needs assistance to idle, then after about two minutes running it will idle high then low. A buddy says it might be the FPR so i'm going to get one and see what happens. Thanks for your input paco.
95ka, idle, maf ka24de, timing issue, vacuum
