Old 02-23-2014, 03:33 PM   #1
JDMBart
Banned from the Marketplace
Trader Rating: (-1)
JDMBart is an unknown quantity at this point
Feedback Score: -1 reviews
KA24DE Idle Issue Please Help
Need some help with my idle. It idles at a steady 1000 rpm but when i apply gas it no longer stays constant and fluctuates around 2k rpms. I have already made adjustments with the idle screw. Any help is appreciated.
Heres the youtube video:
http://www.youtube.com/watch?v=c0SeJ...ature=youtu.be
JDMBart is offline   Reply With Quote
Old 02-24-2014, 05:03 PM   #2
JDMBart
Trader Rating: (-1)
anyone know where to start?
Old 02-25-2014, 06:38 AM   #3
Driftwire
Driftwire's Avatar
Driftwire is an unknown quantity at this point
TPS sensor probably.
Originally Posted by Hoffman5982 View Post
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33 View Post
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
Driftwire is offline   Reply With Quote
Old 02-25-2014, 07:53 AM   #4
90S13hatch_tony
90S13hatch_tony's Avatar
Trader Rating: (24)
90S13hatch_tony is an unknown quantity at this point
Feedback Score: 24 reviews
The idle screw should have been the last thing you check, could of been that the iacv settings were good but now thrown off, check for a possible vaccum leak around the intake manifold, fuel rail, bad injector o-rings, brake booster line...etc
90S13hatch_tony is offline   Reply With Quote
Old 03-06-2014, 10:24 PM   #5
JDMBart
Trader Rating: (-1)
update: ive changed my spark plugs and o2 sensor, cleaned the maf and cleaned the throttle body. I have also fixed two vaccum leaks. My idle is still high after letting off the throttle
Old 03-07-2014, 06:06 AM   #6
s13Cory
s13Cory's Avatar
s13Cory is an unknown quantity at this point
You're saying it idles good, then once you apply gas it starts to bounce to 2k and down? If that's so, then see how your coolant level is. Might need to add some. My friends teg did the same thing and we had to add a lot more coolant and it was good after. I don't know if it'll be the same reason, but something you can check.
s13Cory is offline   Reply With Quote
Old 03-07-2014, 06:37 AM   #7
JDMBart
Trader Rating: (-1)
Yep, coolant level is full. Both the radiator and reservoir were topped off. However maybe it could be a coolant sensor?
Sent from my SPH-L720 using Tapatalk
Old 03-11-2014, 12:49 PM   #8
JDMBart
Trader Rating: (-1)
Update: cleaned my iacv today and it helped a little bit but still seems to idle high
Old 03-12-2014, 01:28 PM   #9
supasan
supasan is an unknown quantity at this point
Sounds like mine. It would idle around 2k then drop down to roughly 1200-1500 for a couple secs then go back up. Found out I had a big exhaust leak where the egr pipe is connected to the exhaust manifold before the o2. not sure if i fixed it or not cause i had to redo my lower timing chain. I'll let you know when its fired up. hopefully this weekend if the weather permits.
supasan is offline   Reply With Quote
Old 03-12-2014, 01:59 PM   #10
JDMBart
Trader Rating: (-1)
okay sounds good, i actually deleted my egr valve so i scewed a plug into the exhaust manifold and bought an isis block off plate for the intake manifold. I am putting on a new tps sensor and throttle body gasket tomorrow. I will keep this thread updated
Old 03-13-2014, 10:32 PM   #11
munkyshet
munkyshet is an unknown quantity at this point
Did you know that the EGR valve is off at idle and WOT? So that delete plate does nothing for you. It's vacuum controlled so as soon as you hit the gas, it shuts off and you are running full on. It only turns on at cruising speeds and light accelerations. This saves your gas and reduces NOx emissions, as well as it saves your cats efficiency in the long haul. IMO, and TLDR, bring the EGR back into play.
Sent from my SCH-I535 using Tapatalk
1992 240SX Vert Stock KA R.I.P.
1993 240SX Hatch Fresh KA
munkyshet is offline   Reply With Quote
Old 03-13-2014, 11:40 PM   #12
Trap Star
Trap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant future
Send a message via AIM to Trap Star
When I deleted my EGR I had similar issues. There is a valve/solenoid, I don't know the official name, that I deleted on accident as well. It has 3 vacuum lines running from it, probably a part of whats used to control the egr (there is a small plug on it as well). Without it the car was having a bit of trouble with stalling at traffic lights or stop signs and while driving I would have momentary loss of power that would get slightly worse if you pressed the gas before suddenly regaining power. So if you accidentally disposed of that it could be you're issue.
86 300zx/90 240sx/97 240sx/96 LS400/03 350z
-Shake N' Break Racing-
Trap Star is offline   Reply With Quote
Old 03-13-2014, 11:54 PM   #13
JDMBart
Trader Rating: (-1)
[QUOTE=Trap Star;5583159]When I deleted my EGR I had similar issues. There is a valve/solenoid, I don't know the official name, that I deleted on accident as well. It has 3 vacuum lines running from it, probably a part of whats used to control the egr (there is a small plug on it as well). Without it the car was having a bit of trouble with stalling at traffic lights or stop signs and while driving I would have momentary loss of power that would get slightly worse if you pressed the gas before suddenly regaining power. So if you accidentally disposed of that it could be you're issue.[/QUOTE
I only deleted the main solenoid that gets blocked off by the egr plate. It had one vaccum line coming out of it but i Blocked that vaccum line off. I ran a vaccum test yesterday and tested 17 hpa which is normal.
Old 03-17-2014, 01:00 PM   #14
Trap Star
Check through this "how to", probably one of the most detailed ones I've seen in terms of pictures and description of what to do. I don't think you are supposed to block the line, I'm pretty sure it needs to be rerouted to work properly. I ended up not having to block any lines after I re-installed that valve I mentioned before.
http://tech.240sxone.com/115/ka24de-egr-removal/
adjustment, high, idle, ka24de, problem
