Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Brakes
Old 01-24-2014, 12:53 PM   #1
FRSport.com
FRSport.com's Avatar
FRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura about
Send a message via AIM to FRSport.com
FRSport Deal of the Day: Motive XLT Bleeder Kit
Bleed brakes like the pros at only a fraction of the cost! The Motive Brake Power Bleeder
uses pressurized brake fluid to safely and easily force air and contaminated fluid out of
your car's lines and hydraulic cylinders. Say goodbye to bleeding and re-bleeding to get
a completely air-free system. Now Brake Bleeding can be a one person operation. Simply
connect the custom adapter to your car's hydraulic fluid reservoir, add fresh hydraulic
fluid to the Motive Brake Bleeder canister, and pressurize the canister with the hand pump.
When a bleed valve is opened, watch the dirty fluid flush out, and the new fluid pour in!
Specs:
  • Heavy-duty pressure tank holds up to 2 quarts of fluid - enough to fully flush and clean most hydraulic systems without refilling.
  • The hand-pump is built in. No other pressure source (air compressor, spare tire) is needed.
  • Precision pressure gauge ensures safe and effective operation. You'll never over-pressurize the system.
  • Thoroughly tested for compatibility with both standard and newer synthetic hydraulic fluids.
  • All Motive Power Bleeders come with a full 1 year warranty.
  • More info here
Available for $145.95
*price good while supplies last add to cart to receive discounted price*
Thanks,
FRSport Team
AIM: FRSportsales
Email: [email protected]
FRSport.com || 18050 Newhope Street, Fountain Valley, CA 92708 (Map link)
Store Hours: Mon - Fri: 8:00 AM - 6:00 PM PST
[email protected] | 800-321-4747 | 714-515-4001 ext 146
FRSport.com Open Box Clearance Items
FRSport.com Weekly Specials
FRSport.com is offline
