Old 12-29-2013, 10:13 PM   #1
alwyzDTF
alwyzDTF's Avatar
alwyzDTF is an unknown quantity at this point
s14 S14/sr treasure
Willing to ship at buyers expense.
Everything is in completely working condition unless posted otherwise.
LOWBALLERS WILL BE IGNORED
S14 SR20DET Blacktop "Kouki" Apexi Power FC - $1100
(Tuned by Lawrence at Intec Racing)
(Comes w/ MAP sensor, AIT sensor, complete wiring, Commander, and original box it came in when purchased brand new)
S15 T28 w/new stainless turbo & oil lines/manifold/outlet pipe - $800
S14 SR Circuit Sports Downpipe - $260
(Little dent/scrapes on bottom but works perfectly also has bung welded in for wideband 02)
Other than the Moonface downpipe, this is the only pre-made oval downpipe that was out on the market, both are now discontinued and hard to find. With a cast stainless O2 housing section and a welded oval downpipe bend it replaces your entire O2 housing and downpipe section and ends with a 3" flange at the cat. This downpipe is the only one that will sit above the frame rails on a 240 other than the moonface downpipe. With the larger volume than most 75mm downpipes you are able to eliminate boost creep.
S14 SR Greddy Pulleys - $240
(also have Greddy alternator pulley in blue but I didn't get a pic yet)
S14 SR Greddy Intercooler Pipe kit - $190
(tapped for AIT sensor and has PLUG for no BOV)
BNIB Z32 30mm oem replacement rotors - $150 shipped
(Bought what I thought were 30mm z32 calipers but turned out the dude didnt know what he was talking about and they tended up being 26mm so these are too big and I can't use them.)
SR20 downpipe (I think its circuit sport) - $60
minor scrape damage, no holes & works perfect
S14 SE OEM Front Sway Bar - $40
(Comes w/ endlinks)
S14 OEM High Pressure P/S hardline - $40
Stance 6kg 200mm springs - $50
(Came off my S14 rear Stance GR+ Pros, selling because I got Swifts)
15mm H&R slip on spacers - $75
S14 OEM Tension Rods - $25
S14 Rear Upper Control Arms - $25
S14 OEM cat + test pipe - $30
S14 steering wheel - $60
S14 airbags - $50 (for all)
S14 KA radiator - $50
[B]S14 OEM front calipers - $50
SS lines - $50
front rotors - SOLD
Stance GR+ Pro tender springs - $60
alwyzDTF is offline   Reply With Quote
Old 12-30-2013, 06:45 PM   #2
alwyzDTF
alwyzDTF's Avatar
Also have an SR oem driveshaft and an S14 SR Apexi Power FC D Jetro w/ map setup for sale as well.
both in spectacular condition.
Old 12-31-2013, 07:23 AM   #3
glacier985
glacier985 is an unknown quantity at this point
Will you do $35 shipped on the clockspring to 43025? Throw in a flat rate box?
72 240z, l28, Its a classic
90 240sx, ka24et Get this finished
glacier985 is offline   Reply With Quote
Old 01-01-2014, 09:02 PM   #4
alwyzDTF
alwyzDTF's Avatar
PM'd you man!
Old 01-02-2014, 10:24 AM   #5
alwyzDTF
alwyzDTF's Avatar
Sold, just received payment buddy! Will be shipped off by this weekend.
Old 01-02-2014, 11:17 AM   #6
alwyzDTF
alwyzDTF's Avatar
S14 Sr Apexi Power FC complete setup/ S14 SE front sway bar added to the thread
Old 01-02-2014, 08:58 PM   #7
alwyzDTF
alwyzDTF's Avatar
SR elbow is now sold.
Old 01-03-2014, 11:35 AM   #8
alwyzDTF
alwyzDTF's Avatar
Kouki headlight pending sale.
Old 01-03-2014, 08:04 PM   #9
alwyzDTF
alwyzDTF's Avatar
Kouki headlight just sold!
Old 01-05-2014, 02:08 PM   #10
alwyzDTF
alwyzDTF's Avatar
Weekend bump
Old 01-19-2014, 11:03 PM   #11
alwyzDTF
alwyzDTF's Avatar
late night bump
Old 02-08-2014, 01:53 PM   #12
alwyzDTF
alwyzDTF's Avatar
weekend sales pending. Bout to make a new thread with some more s14 and sr stuff.
Old 03-06-2014, 10:33 PM   #13
alwyzDTF
alwyzDTF's Avatar
bump bump. ttt.
Old 03-08-2014, 04:42 PM   #14
alwyzDTF
alwyzDTF's Avatar
weekend bumps
Old 03-08-2014, 05:14 PM   #15
Tech_s14
Tech_s14 is an unknown quantity at this point
Pm sent
Tech_s14 is offline   Reply With Quote
downpipe, greddy, kouki, s14, sr20det
