Old 11-23-2013, 11:48 AM   #1
914Slide
914Slide's Avatar
914Slide can only hope to improve
CA ca18det Help Please
hey i recently put a new heater core in and ever since i haven't been able to drive the car, it has been overheating :/ ik ive bled the system properly and even tried bypassing the core again because it worked fine before the heatercore. there is a noise coming from the front of the timing case around where the water pump is. ????????????????? idk please someone shine some light i need my car back
914Slide is offline   Reply With Quote
Old 11-23-2013, 01:41 PM   #2
Nissan_Alex
Nissan_Alex's Avatar
Nissan_Alex is an unknown quantity at this point
Check the play in the front bearing of the waterpump, if it has play your culprit is the waterpump.
Nissan_Alex is offline   Reply With Quote
Old 11-23-2013, 07:25 PM   #3
914Slide
914Slide's Avatar
there's a small amount of play if you wiggle it but it spins freely, also nothing is going on when i have the rad cap off and spin the pump ?
ca18det, coolant leak help, radiator hoses, s13 240sx, water pump
