Old 08-01-2013, 10:19 PM   #1
203692
203692 is an unknown quantity at this point
no spark might be cas or ecu. Please help
so i am finishing up my sr20det redtop swap into my 91 s13 hatch. My buddy and i did everything by the book and took our time.
We crank it for the first start and jst turns over but nothing further from there.There is no spark. We have traced the issue and ran blink codes and traced it back to being either the CAM SENSOR or the ECU.
I did some research before coming here and noticed that the cam sensor should have between 0.1 and 5 volts coming through it. I tested it. The first 2 prones showed no reading on my voltage reader when tested next to each other. When i tested other prones and combined others with the first 2 i recieved random readings like 5.32, 7.21, 12.25.
IDK if this means my ECU is sending bad signals therefore it's fried, or my sensor is bad.
Someone Please Help. Thanks
203692 is offline   Reply With Quote
Old 08-02-2013, 06:23 AM   #2
Mikester
Mikester's Avatar
Make sure your harness and coilpack harness etc are properly grounded.
Old 08-02-2013, 01:30 PM   #3
203692
what do u mean by ground the wiring harness? like make sure the ecu is grounded?
Old 08-02-2013, 01:36 PM   #4
203692
nvm i misread that. i'll make sure the coilpack and everything is grounded and get back to u thanks
Old 08-02-2013, 02:48 PM   #5
203692
so i checked all the grounds and made sure they were on well and still nothing. Any other suggestions?
The ECU has a solid red light on when the power is on if that helps any.
cam angle sensor, ecu, no spark, sr20 redtop, won't start
