Old 06-20-2013, 09:48 PM   #1
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
Idahotuner Sr22 gt3076r silvia front DRAG & DRIFT$9000 OBO
price dropI have admitted defeat finally, the redneck in me has won and i belong in the woods more then zooming around on the streets, and like most projects once you get them where they are running good and you can enjoy them, you feel the need to move on.
So i am selling my 1993 240sx, for a low price of $9000 OBO DRAG AND DRIFT SETUPS Call or text my cell 208-five8two-1341 IF YOUR SERIOUS
Its been a long time coming 5 years and 2 engines later to get it to this spot, i will start off with the bad before i list mods or anything,
Paint and body is 95% painted 4 years ago, normal wear and tear of being a lowered car.
and two if the car sitting in one place it has a tinny oil leak from the upper oil pan seal, on the back of the engine, not enough to be noticeable in oil use.
Now the GREAT and good 2500 MILES on new engine
RELIABLE could hop in it and drive to cali no problem
Good:
131,000 Miles on the body
Silvia front end
CS corner tinted
CS clear covers for brick head lights
silvia center bezel
Engine block is a mazworxs 2.2 block
90 mm bore, eagle rods, and cp pistons
compression ratio of 9.1 to 1
darton sleeved
cleavite coated bearings
whole rotating assembly balanced including flywheel
Over sized oil pan
Head has a port, polish and knife edge on exhaust side.
3 angle valve job
JWT bronze valve guides
BC 264 cams
Bc springs
valves reshimmed and spring seats installed
CS rocker arm stoppers
Air flow
Apexi z32 intake filter
z32 MAF
4 inch custom aluminum intake, that positions the filter down under passenger side head light
Turbo is a gt30r front housing and center, the turbine house is a gt32 twin scroll housing that has been bored for gt3076 exhaust turbine, the ar is .82
greedy LS front mount intercooler cools the air
HKS BOV
isis instake manifold
Out through :
FULL_RACE twin scroll manifold w/ 40mm tial wastegate
mazworxs dump tube
FULL_RACE turbo outlet
Full 3 SS turbo back exhaust / new CS bushings
Brakes
Z32 front frakes
ss lines
z31 bmc
brembo drilled and slotted rotors
back brakes need new pads
FUEL
Intake Walbro 255 flows to an inline 255 fuel pump, hard wired with two relays and two fuses
MSD 96# fuel injectors
MR fuel pressure regulator
ELECTRONICS
Enthalpy Dual tune ECU
Wiring specialties harness just installed s13 to s13sr
AVCR boost controller
AEM wideband
SPLITFIRE coil pack
Autometer boost gauge, oil pressure, oil temp, water temp, egt (which isn’t hooked up)
COOLANT
Mishimoto Radiator
Dual Mishimoto fans and shroud, ignition wired through a relay with fuse
sr20de thermostat
cs hoses
Drivetrain and suspension
B&M shifter
ACT 6 puck clutch and pressure plate- new with engine
ACT flywheel
s15 HLSD
PBM coilovers
Isis RUCA
tein tierods
ES bushings, every single one is replaced including rear subframe ones
Drag SET UP included rand a 12.4 with it spinning 2&3rd still EDIT my et was 116 mph, and i am throwing this stuff in as a bonus
255x60x15 Mickey Thompson Street ET slicks lots of life left, 7 passes by me
Stock rear suspension
Drift, 4 extra tires and the PBM suspension is everything you need
Lots of extras I can throw in and i am sure i am missing stuff, i hate it when people post how much money they have in it ad how much of a deal they are giving you, i will let the parts speak for themselves, and i have 95% of the receipts
I am willing to meet, if its a agreeable distance, dyno will happen here as soon as the next dyne day, should be 450ish at the wheels around 20-24 psi
dyno sheet 25 psi
idahotuner is offline   Reply With Quote
Old 06-20-2013, 10:05 PM   #2
xGUNKX
xGUNKX's Avatar
xGUNKX is making his/her stupidity well-knownxGUNKX is making his/her stupidity well-knownxGUNKX is making his/her stupidity well-known
I may want this w/o slicks/drag setup
Originally Posted by Darryl
Them Hondas can get pretty fast if you fix em up right
xGUNKX is offline   Reply With Quote
Old 06-21-2013, 01:34 AM   #3
TheRealSy90
TheRealSy90's Avatar
Idk how I never heard of this car when I lived in Idaho lol. You must not be on IMS?
Such a good signature.
Old 06-21-2013, 07:53 AM   #4
JN1AS4
JN1AS4's Avatar
JN1AS4 is an unknown quantity at this point
When you went 12.4 in the 1/4 mile what was your mph?
JN1AS4 is offline   Reply With Quote
Old 06-22-2013, 11:23 AM   #5
idahotuner
Ran a 116 mph in the quarter. Thanks for checking it out guys
Old 06-22-2013, 12:01 PM   #6
JN1AS4
JN1AS4's Avatar
12.4@116 on how many psi? 17-18psi?
Old 06-22-2013, 12:43 PM   #7
idahotuner
20-23 wasn't hooking up in 2nd or 3rd . Ran 113 on ten
Old 06-22-2013, 12:44 PM   #8
pistons
pistons is an unknown quantity at this point
Very nice car good luck with the sell.
pistons is offline   Reply With Quote
Old 06-22-2013, 09:01 PM   #9
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
nice car..looks good
Old 07-09-2013, 06:38 AM   #10
idahotuner
Price drop
Old 07-09-2013, 06:54 AM   #11
2forty
2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of
Thought it would trap much higher on 16-17psi. Super clean though.
TEAM SKIDMARKS Carbon black S13 SR Coupe
2forty is offline   Reply With Quote
Old 07-09-2013, 08:22 PM   #12
idahotuner
yeah it would if i hadn’t wasted distance and time not hooking up in second and third
Old 08-03-2013, 06:53 AM   #13
idahotuner
490 hp at 25psi 454 ft lbs
Old 08-03-2013, 09:23 AM   #14
project06tj
project06tj's Avatar
project06tj is an unknown quantity at this point
Open to 4x4 trades?
project06tj is offline   Reply With Quote
Old 08-03-2013, 12:47 PM   #15
zane
zane is an unknown quantity at this point
What a good deal for a solid car! Lots of money into that engine.
Good luck with the sale
zane is offline   Reply With Quote
Old 08-03-2013, 01:02 PM   #16
teamsprock
teamsprock's Avatar
teamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the rough
Pretty impressive numbers. I think my brother has been talking to you about the car and elk hunting. Looks like even more power could easily be made decreeing the cams or running a bigger cam. Nice work. I keep encouraging Jake to come get this because it reminds me of my older mazworx twin scrolled setup minus the headaches of solid lifters and huge cams. Good luck with the sale!
teamsprock is offline   Reply With Quote
Old 08-03-2013, 01:27 PM   #17
idahotuner
Yeah. I actually have a few guys in billins talking to me. But yeah your bro mentioned your car. Just need on a different dyno that can really load the car up. I think the rollers were maxed asfar as load
Old 08-12-2013, 11:27 AM   #18
idahotuner
8500 bottom line before I part it out
Old 08-12-2013, 01:24 PM   #19
AwesomeO
AwesomeO is an unknown quantity at this point
so trades or no? lol just making sure
AwesomeO is offline   Reply With Quote
Old 08-12-2013, 01:55 PM   #20
idahotuner
trades if it is a stock car and i need at least 6000 ontop
Old 08-12-2013, 09:00 PM   #21
tayloray
tayloray has a spectacular aura abouttayloray has a spectacular aura abouttayloray has a spectacular aura abouttayloray has a spectacular aura abouttayloray has a spectacular aura abouttayloray has a spectacular aura abouttayloray has a spectacular aura about
Someone buy this. Crackhead deal
tayloray is offline   Reply With Quote
Old 08-12-2013, 09:18 PM   #22
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Hot damn 490whp 450wtq on 25psi lol.
I'm on a GTX3076 street tuned on 20psi. Very similar build. Just a 2.0 with +1mm valves is about the only difference. Shits ridiculous you made that much power lol
Beautiful and very professional build. I'm in love with it! GLWS
When do you get full boost? And those AFRs seem dangerously lean for WOT. Nearing 13:1
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 08-12-2013, 09:54 PM   #23
idahotuner
you can’t trust the are from the dyno they stuck it up the pipe, my wide band reads 11.5 solid. and my torque drops off cause the manual boost gauge line popped out so boost dropped didn’t stay ramped up. waste gate was closed solid
Old 08-12-2013, 09:55 PM   #24
idahotuner
4300 full boost maybe 4400 on the street it goes from 20-30 psi in 200 rpm is nuts
Old 08-12-2013, 10:01 PM   #25
EsChassisLove
Trader Rating: (26)
Ah gotcha, mine was read through the ECU. None of that tail pipe funny business.
Still great power man. Those tires don't stand a chance.
Old 08-13-2013, 10:53 AM   #26
idahotuner
http:// http://m.youtube.com/watch?v...o&feature=plcp dyno video. My wife was recording that's why there is a shot of my ass loo
Old 08-26-2013, 10:20 AM   #27
idahotuner
This car is going in storage soon if it doesn't sell
Old 08-29-2013, 10:21 PM   #28
idahotuner
Sold the car
drift, full-race, mazworx, silvia, twin scroll
