05-25-2013, 04:40 PM | #1 |
Ichiba 5 lug conv.Wheel studs size???
Hello everyone,
So I'm looking to replace my studs that came with the Ichiba front 5 lug conversion. I have been lurking around for awhile and can't find their exact specs for the normal NON EXTENDED studs that they use in the kit. In their description, I know it says that they use OE length studs, however when I went to Oreilys to pick up some OE s13 studs, they appeared to be too thin and not right at all. It's a possibility that they gave me the wrong studs, but I am not sure. I tried s14 studs as well and they seemed like they may work if spanked in, but before I do that, I'd like to be certain. I also read on Ichibas description, that the studs are 14.30mm knurl size and are the OE lengths, been to a few parts stores and everyone says I need the exact specs so they can look them up. I tried calling ichiba, but I believe they are closed for the weekend. I would bring my old studs, but they slightly exploded at a shop via a press. haha I may just resort to pulling off my other hub and take that in to see if they can match it, but just wanted to see if anyone else had this issue in identifying the exact studs Ichiba uses in their 5 lug conversion. Thank you sports!! |
06-15-2013, 04:20 AM | #3 | |
Should be S14 Studs, that's what I read and will be doing mine this weekend.
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got |
5 lug, ichiba, s13 |
