Old 04-24-2013, 11:38 AM   #1
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
To: All w/ ATI Super Damper on a sr20 (s14)
My ATI Super Damper seems to have different pulley sizes than the stock crank damper/pulley. I don't know if this is normal or if I may have gotten the wrong one, (I got it thru FRsport).
I have had to buy a new power steering belt because of this and it looks like the water pump/alternator belt will not work either.
Now I am starting to get concerned about under-driving them because the crank pulleys are a bit smaller...
Has anyone else dealt with this problem?
Thanks,
bc
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
Old 04-24-2013, 12:09 PM   #2
SaVAgES14
SaVAgES14 is an unknown quantity at this point
What's the part number on the one you have?
SaVAgES14 is offline   Reply With Quote
Old 04-24-2013, 12:10 PM   #3
bc.
bc.'s Avatar
Good question, I will have to check when I get off work.
Old 04-24-2013, 06:06 PM   #4
bc.
bc.'s Avatar
number on the sticker is 692482
Old 04-25-2013, 04:43 AM   #5
BoostinIX
BoostinIX's Avatar
Trader Rating: (29)
BoostinIX is an unknown quantity at this point
Feedback Score: 29 reviews
Send a message via ICQ to BoostinIX Send a message via AIM to BoostinIX Send a message via MSN to BoostinIX Send a message via Yahoo to BoostinIX
Right there on the FRSport page from this:
The Super Damper does not retain stock belt size. You will need to measure for the correct belt size.
ATI Performance Super Damper Harmonic Crank Pulley Nissan SR20
BoostinIX is offline   Reply With Quote
Old 04-25-2013, 06:49 AM   #6
bc.
bc.'s Avatar
Haha, thanks, I think I remember that now
Old 08-19-2016, 03:16 PM   #7
claaasssiiiccc21
claaasssiiiccc21's Avatar
claaasssiiiccc21 has a spectacular aura aboutclaaasssiiiccc21 has a spectacular aura aboutclaaasssiiiccc21 has a spectacular aura aboutclaaasssiiiccc21 has a spectacular aura aboutclaaasssiiiccc21 has a spectacular aura aboutclaaasssiiiccc21 has a spectacular aura about
To update this for all to reference: S14 SR20DET w/ATI pulley (newer under-driven one)
PS: 3PK860 is ideal. 3PK855 will also work no problem and is more common (Gen 2 Prius PS belt)
AC: 4pk880 - same as stock
Water/Alt: 5PK920 is ideal. 5PK918 is more common and is tough to get on, 5pk925 works but with Quest alternator conversion mine was a hair off of the stock low pressure PS return line, so I went with a 5PK920.
LSB E46 M3. Causing my S14 to collect dust since 2009.
claaasssiiiccc21 is offline   Reply With Quote
Old 08-19-2016, 03:29 PM   #8
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
holy shit i think this is the FIRST time i've ever seem someone bump a graveyard thread with information that was actually useful!!!
thank you claaasssiiiccc21, thank you
Old 08-19-2016, 03:41 PM   #9
STEEZxIT
STEEZxIT's Avatar
STEEZxIT is on the path to ruinSTEEZxIT is on the path to ruin
wow dude, good call!
@dangerdamian
STEEZxIT is offline   Reply With Quote
Old 08-20-2016, 12:13 AM   #10
claaasssiiiccc21
No problem guys, I know a lot of guys have good info out there, just wish more people took the time to share it
Old 08-20-2016, 09:51 AM   #11
tacotacotaco
tacotacotaco's Avatar
tacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfection
Send a message via AIM to tacotacotaco
The kind of people zilvia needs again! +rep point
tacotacotaco is offline   Reply With Quote
Old 08-20-2016, 10:59 AM   #12
TheRealSy90
TheRealSy90's Avatar
So since I'm thinking about it. The ATI damper underdrives everything.
I have a Yashio Factory water pump pulley that also underdrives the water pump. Would combining these two be "too much" underdrive on the water pump? Or would it probably be fine or even more beneficial.
Such a good signature.
Old 03-05-2018, 12:05 AM   #13
Sr20-Vert
Sr20-Vert's Avatar
Sr20-Vert is a well-known jackass
Anyone know what works for s13 I got the s14 was not enough ribs
Sr20-Vert is offline   Reply With Quote
Old 03-05-2018, 08:52 AM   #14
jedi03
should be able to use the s14 one...under driving I have never seen one that is to much, my uncle uses a really slow electric pump on his mustang...cant turn more than 20rpm...but flows enough to keep things cool...check your temps after you run it and you will find out!
Old 03-05-2018, 11:06 AM   #15
brndck
brndck's Avatar
The first number should be number of ribs. Second number is length. So if you have a 4pk880 and you need another rib, ask for 5pk880
Old 03-09-2018, 12:50 PM   #16
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
mr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond repute
Feedback Score: 31 reviews
Since this thread is being bumped from the dead haha...
Did you ever get an answer to your question?
Sent from my SM-G955U using Tapatalk
mr.nismo. is offline   Reply With Quote
Old 03-09-2018, 05:57 PM   #17
brndck
brndck's Avatar
I think the best method would be to try it.
There are tons of variables involved like where you live, what season it is, if your car is a daily or track only, if you have good ducting, etc.
If that setup allows you to reach operating temps, and keeps the car cool when flogged, then I'd say go with it. If it stays cold, switch back to an OEM size water pump pulley.
Old 03-09-2018, 06:05 PM   #18
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
My only worry would be being too underdriven at idle, and possibly lead to overheating
