loud roaring sound from right front end 95 s14
Pls help if anyone knows i have a loud roaring or deep grinding sound coming from my front end but only from the right side it only happens when i reverse and it happens weather my wheels are straight or turned just only when im reversing its not hitting anything that i can see it hasent in the past and nothing new has been done i have no idea what it could be any suggestions??
The obvious first idea is that your wheel bearing is going bad. Jack up that cornere and try to wiggle the wheel. If it wobbles then the bearing is definately going to need replacing.
Wheel HUB was changed a month ago brnd new one and hace not hit anything and like i said it only does it in reverse its not coming from the wheel its coming from somewhere more towards theaxle or tie rod area
#5 |
![]() Join Date: Jun 2007
Plastic inner fender lining + blown tension rod.
How about jack the car up and see if you can figure it out, whatever it is, it sounds like it should be obvious.
#8 |
What about the brake shield? Is it rubbing on the rotor anywhere? I woudnt expect a tension rod to make that kind of noise but I suppose anythings possible depending on what is actually wrong.
