Old 04-15-2013, 11:50 AM   #1
spartan
spartan is an unknown quantity at this point
Battery issue
Decided to swap my redtop optima battery from my ep3 an put it in the s14 but as soon as I tried to start the car it lost all electical power and does not even try to turn over. Put the old batter back on and same thing happen. After about 20 mins the got power back an took about 30 seconds to finally turn over. So what gives? maybe replace terminals? or the replace connectors? i dont see how it could be a ground wire if one batt works an the other better batt doesnt?
spartan is offline   Reply With Quote
Old 04-15-2013, 12:50 PM   #2
rwtf
rwtf's Avatar
rwtf is an unknown quantity at this point
check main fuses in the engine bay
rwtf is offline   Reply With Quote
Old 04-15-2013, 01:18 PM   #3
spartan
i did the fuses are fine
Old 04-15-2013, 01:40 PM   #4
KoukiMonsta
KoukiMonsta's Avatar
sounds like poor connections, the usual reason for electrical issues
@UpshiftEngineering
Old 04-15-2013, 01:53 PM   #5
spartan
yea im gonna try getting new ones as well.
can you guys recommend me a optima?
I was using a 100ca and 800cca when i tried the swap
Old 04-19-2013, 10:17 PM   #6
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Optima makes a nice unit, but I'd never spend the cash on one. Any good battery will work for you without issue.
Sort your connections out!
