![]() Alright I bought this car summer of 2011, stock ka, clean title, clean body. last January i pulled out in front of a car on a residential street and got the quarter panel damage in the pics below. When it was parked i had the driver door open while i ran to the trunk and someone came down my street and practically took the door off. The insurance company totaled it from that incident, not from the prior. The quarter panel damage messed up the bumper as well but there is no frame damage at all, its a straight body, i still drive it, it drives straight.
Now that we have that out of the way. The engine blew the headgasket last February so i rebuilt it and decided to turbocharge it as well. As it sits now the engine itself runs really nicely except at idle, because of the tune after any kind of pull it wants to die once you put the clutch in or put it into neutral. Yes the blow off valve is recirculated so that is not the issue. other than that the car drives well. Made 258 hp at import auto pros in Westminster where i had them fine tune the enthalpy ecu i had with an Apexi Afc Neo. Specifications: Registration: just went out in February, needs to be smogged (no egr, canister or emmisions related stuff on the engine) Title: salvaged Year: 89 Transmission: manual Rebuilt: engine had 135xxx when it blew the gasket, since rebuild there is approx 2000 block decked and honed OEM piston rings Clevite bearings (rod and crank) Polished crank Arp head studs Cosworth 3-layer head gasket New valve stem seals Other stuff: N60 maf Blitz nur spec exhaust Circuit sports short shifter walbro 255 fuel pump Battery relocated to back sr 370 injectors s14 T28 BB (seals are blown so the car blows blue smoke) ** have another t28 i bought off of someone from here that is in good condition with no shaft play but i broke off two bolts in the exhaust housing when installing it.) this will be included with the car Apexi Super suction intake Isis 3" elbow 3" catco highflow cat 3" sr downpipe no name exhaust manifold (bottom mount) ebay intercooler and piping (front mount) enthalpy ecu tuned for t28,n60,sr injectors Authentic HKS bov. gen1 aluminum cx racing radiator Taurus fans Lightened flywheel oem mud flaps oem chucki lip Aluminum 1 piece drive shaft Aluminum BMC heat shield Innovate wideband sensor and gauge Apexi AFC neo Throwing in: Q45 calipers spare n60 maf spare oem sr elbow I think that's everything. I don't have a set price i just would like to see what i can get for the car as a whole, if i dont get any offers then i will part out. Texting me will be the easiest way to get a response (562) five zero six 4943. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#14 |
![]() Join Date: Sep 2012
![]() Feedback Score: 7 reviews
you should part it out I may have interest in Enthalpy tune (thats if its real RS Enthalpy) along with AFC Neo and Blitz NUR Spec exhaust depending on condition if it didn't get rapped in the wreck.
Haters gonna hate ![]() |
#15 |
didn't see the innovative wideband gauge and aluminum driveshaft. Want more info and pics. Hope you partout and junk the shell. Probably will make more money than 1k offers
#16 |
@gotdrifttoday, a grand is a little cheap
@jayycob, ill let you know if i don't sell, id be willing to sell the front end @bathsaltsamurai, pm'd you thanks for the basketball idea i might give that a try. and yea i work at tutti frutti so its parked there a lot. |
apexi, coupe, ka-t, s13, turbo |
