Old 02-28-2013, 04:35 PM   #1
93coupe07
93coupe07 is an unknown quantity at this point
s13 fuel pump not primimg helpppppp
hey guys i have a redtop s13 just tried to turn her over for the first time today butttt...my new walbro isnt kickin on at all i really have never had this issue with the sr swap guy have any ideas/suggestions thanks a ton
93coupe07 is offline   Reply With Quote
Old 02-28-2013, 04:45 PM   #2
Iconik
Iconik is an unknown quantity at this point
If the pump isn't priming the first thing I would be doing is checking for correct powers and grounds at the pump connector. Also make sure there is good pin contact in the connector.
If you've got no power there then you have a wiring issue, as you've just completed your swap by the sounds of it there is a good chance you simply missed something, wired something in the wrong way or something got pinched upon install.
Iconik is offline   Reply With Quote
Old 02-28-2013, 08:31 PM   #3
s14newb
s14newb is an unknown quantity at this point
What chassis is it, s13 or s14?
s14newb is offline   Reply With Quote
Old 03-01-2013, 02:16 PM   #4
93coupe07
Its s13 chassis and i know its a wiring problem i guess i just dont know where to start looking not sure what part of the harness goes or sends power to the fuel pump ive checked all relays and fuses and the wiring by the battery box
Old 03-01-2013, 02:18 PM   #5
93coupe07
And one pin at the connector to the pump has 12v with key on not sure which wire is for what on the connector in the trunk
Old 03-01-2013, 02:38 PM   #6
KoukiMonsta
KoukiMonsta's Avatar
Black with yellow stripe supplies fuel pump with power. Check if it had 12v with the key 'on'
If not, start with fuse. And work towards relay/pump with multi meter
@UpshiftEngineering
Old 03-02-2013, 07:57 PM   #7
steve shadows
steve shadows's Avatar
If the fuse is good and the wiring is good then I would check the actual pump. I have had walbros lose the filter right after putting it in and fail right away.
Like Me on FaceBook !
fuel pump, help 240sx, problem, s13, sr20det
