02-10-2013, 11:09 PM | #1 |
FS 1991 Mazda rx7 vert rolling shell
I'm finally letting my 91 Rx7 dd project go. I blew a coolant seal driving it around a while back, I had a replacement engine for it, so I pulled the motor and had both the old and new engines next to each other, unfortunately both engines were stolen as they sat outside. I also had a spare Turbo II engine that I had planned on swapping in, but it was stolen a long with my enclosed racecar trailer, so I've decided to let it go so I can put the money towards my actual drift car.
You'll need to get another engine to put in it, I am also taking the Sparco seats out and using them in another car, so you'll need to find something to replace them with as well. I also have an N/A 5 speed transmission and driveshaft that will come with the car if you want them. The interior is pretty clean, I removed the carpet and shampooed it all when I first picked the car up, the convertible top has no leaks and works fine, power windows also worked good the last time I drove it. The switch panel for the top (located ner the center console) doesnt stay clipped down, not a real big annoyance to me at least. It has 5zigen FN-01RC wheels, 17x9 +20 (fronts) and 17x10 +35 (rears). Also has some shitty coilovers, cusco's in the rear, I can't remember what the fronts are, but they do have adjustable camber plates. Good -Pretty clean interior -Power windows work -Straight body -S5 rx7 -Convertible top works well -Clean title in my name -5zigen wheels Bad -Missing engine -Needs 2 seats -needs a paint job -needs battery -needs radiator Looking to get $1,000 obo, not too into trades at this point. It's located in Colorado. |
convertible, drift, mazda, rx-7, rx7 |
