02-09-2013, 05:28 PM | #1 |
OEM thrust Washers and grades..
Hello,
It's probably rather stupid question, but after a-bit googling and such I found no real good info on the thrust washers. I'm gonna buy em OEM but the main and rod bearings are ACL, the crank is machined and balanced, will the grade the crank tell me about the main bearings apply for the thrust washers, or can I just go for whatever I may feel for ? Grade is 0-6 just as the mains n rods.
OakHeart Racing |
02-09-2013, 05:43 PM | #2 |
There is only one size for the thrust washer
02-09-2013, 06:01 PM | #3 |
Yep, only one size thrust washer. If your lateral endplay is out of spec then the crank itself is no good but ive yet to ever see that happen. The endplay has a pretty wide spec. Just get yourself an OEM or ACL thrust washer and be set. No need to mess with it.
02-09-2013, 06:05 PM | #4 | |
OakHeart Racing |
