Old 02-08-2013, 09:54 PM   #1
Likstreetracing
Likstreetracing's Avatar
Likstreetracing is an unknown quantity at this point
s13 Headlight Problem
Hi I have a 91 240sx coupe and I did the sleepy eye mod when I first bought the car about 3 years ago. I did it by taking off the relay on the right front side of the car and jumping the wires hooked up to switches. It worked fine until now, I checked my powers and grounds and I checked every single fuse in the car until I found out I had a blown fuse right next to that relay. I hooked up a fuse and removed the sleepy eye mod then installed the relay back up. Now, one headlight goes up and the other goes down, I then hit the headlight switch and one goes back down and the other goes down. Has anyone had this issue I swapped relays and nothing happened.
Likstreetracing is offline   Reply With Quote
coupe, diagnosis, headlight, headlight timer, wink
