Old 10-29-2012, 08:25 PM   #1
RBMadess
RBMadess is an unknown quantity at this point
s13 Nissan 240sx s13 complete oem suspension
Friend of mine installed aftermarket suspension arms on his 240sx and we no longer need these. Everything is in fair condition when I removed them, no play in the bushings at all. Some of the bushing boots are torn but the actual bushings are still good. Price is $100 obo for everything listed here. Open for trades, please be reasonable. 714 483 8563.
Front Left Lower control arm
Front Right Lower control arm
Front Right tension arm
Front Left tension arm
Front Left inner toe rod
Front left outer tie rod end
Front Right inner tie rod
Front Right outer tie rod end
Front Anti-roll bar
Front Bearing/Hub assembly, if I can find it(4 lug)
Rear Right Lower control arm
Rear Left lower control arm
Rear Right toe arm
Rear Left toe arm
Rear Right traction arm
Rear Left traction arm
Rear Right Upper control arm
Rear Left Upper control arm
Rear Sway bar
Rear bearing/hub assembly, if I can find it(4 lug)
RBMadess is offline   Reply With Quote
Old 10-31-2012, 03:08 AM   #2
RBMadess
BUMP I thought someone might want these. They're taking up space in my garage. 60 picked up, hmu.
Old 07-27-2016, 02:49 PM   #3
Perrisimo777
Perrisimo777 is an unknown quantity at this point
Front Right tension arm, Front Right Lower control arm
Hello
Do you still happen to have those parts available??
Perrisimo777 is offline   Reply With Quote
Old 07-27-2016, 04:33 PM   #4
KJR50
KJR50's Avatar
KJR50 is an unknown quantity at this point
really now? 4 years later, i hope not.
KJR50 is offline   Reply With Quote
arm, control, lca, rod, s13
