Old 10-27-2012, 08:40 AM   #1
Danger_Dorn
Danger_Dorn's Avatar
Danger_Dorn is an unknown quantity at this point
JGS motor mounts
I got my motor and trans mount today. Not only was the motor bracket hole too small, they didn't come with a nut for the top threads....? Does anyone know the size and pitch?
Posted from Zilvia.net App for Android
Danger_Dorn is offline   Reply With Quote
Old 10-27-2012, 10:06 AM   #2
smartoss
smartoss is an unknown quantity at this point
From their site: "Only one small modification is required, the engine to MM bracket hole must be drilled out to 7/16" (11mm). This is very easy and can be done without removing the brackets."
bring the mount into Ace hardware and they will get some bolts for you.
smartoss is offline   Reply With Quote
Old 10-29-2012, 04:09 AM   #3
Danger_Dorn
Well I got them figured out and put in. You have to re use the nut for the frame on the bottom of the mount. Also, I hat to dremel out the holes of the motor bracket. It was pretty easy. They are both in and seem super stable. Ill test them out after I get my hear back together. Thanks for the help guys.
