Old 09-04-2012, 09:49 PM   #1
TeamMayhem
TeamMayhem is an unknown quantity at this point
Thumbs up Fs/FT 1991 Nissan 240sx RHD Type X Kouki SR20DET Trade for 97-98 240sx
CAR HAS BEEN SOLD TO 86kid!
Thanks zilvia! Mods please close
Vehicle for Sale
Year:1991
Make:Nissan
Model:240sx
Trim:SE
Engine:SR20
Transmission:MT
Color:White/black
Mileage:73,343 km
Price:10,800 OBO Trades welcome $
Phone #:860-908-2668
Mods: see description
Rust: NONE - Southern Car
Mechanical Condition:10/10
Body/Interior Condition:8/10
Pics/Other Info:
Up for sale is my 240sx. I'm selling to buy a 97-98 kouki or s2000 in the spring. Cash is king and will take any reasonable offer. OPEN TO ALL TRADES! Especially s2k or 97-98 240sx. I would prefer stock but if modified thats fine also, in the end i will be doing a 2jz swap regardless. I am also looking for Toyota tacoma 4x4's to replace my daily. The worst i can say is no.
I just had this car appraised. It was accesed at $11,890. So if your looking to get a car loan the bank will accept the appraisal for the amount of $11,890. I have all documents.
Clean Title in hand.
It started out as a bone stock 91 240sx SE that i purchased in Charlotte NC and drove back to CT, the Body is TOTALLY rust free and have 50+ pictures of the cars underbody on a lift.
From there i started collecting the Type X Aero, The wing, side skirts, and rear valences i had imported, The bumper with every metal brace that nissan had on it, fender extenions, turn signals, running lights, all pigtail harnesses, 180sx crash support, 180sx foam bumper support, Nissan bumper emblem, 180sx kouki Tails, ect was all purchased new from Russ at NissanParts.CC and have the receipt for $1598
I did the RHD swap myself and did it the right way with no expense spared taking multiple X measurements on the front end to make sure that the body is reassembled strait , i have hundreds of pictures throughout the swap. all 3 major peices (inner and outer cowl followed by the firewall) were carefully removed by using a Spot weld driller that i purchased from Snap On from both the front clip and car. From there i primed both sides of each panel with weldable primer to prevent rust betrween all seams. i then intalled the peices and welded the panels in using the existing spot weld holes. After the panels were welded I used 3M Seam sealer on all seams. Finally i laid on 2 coats of Spies Hecker primer followed by 2 coats of BMW Alpine white and 3 coats of clear. Realistically all this car needs is paint.
My goal with this project was to have a fully functional RHD Vehicle with all the JDM amenities, (climate control, jdm doors, power folding mirrors and Functioning A/C ect)
Engine:
S13 SR20DET Blacktop
60k miles
New*
valve cover gasket
NGK Iridium spark plugs
belts
thermostat
turbo gasket
7 layer stainless exhaust manifold gasket
oil changed 8/10/12 with Mobil 1 15w/50 oil with K&N oil filter
Greddy Front mount intercooler with Greddy Type RS Blow off valve
HKS aluminum suction intake with K&N air filter
Mishimoto 2 Core radiator with 2 10' electric S blade fans mounted to mishimoto aluminum shroud
Full 3" exhaust
Circuit sports 3" turbo outlet
Circuit Sports 3" downpipe
Circuit Sports 3" Testpipe
Amuse Titanium Cat Back. 1pc titanium fully tig welded. Cost me $1100 imported from japan
Heavy duty triple pass Power steering cooler
AEM Tru Boost, Electronic boost controller set to 12psi
AEM Wideband Air/Fuel Gauge
Summit racing Digital water temp gauge
Spec stage 4 Clutch
B&M Shifter
BODY:
Type X Aero thats 99% complete, Only need front lip
Kouki Tails
Engine Bay Sprayed BMW Alpine white with Spies Hecker paint
JDM 180sx doors with power folding mirors and window switch on the right side.
SUSPENSION:
Stance GR coilovers with Z32 lowers for Z32 aluiminum uprights
Z32 aluiminum uprights powder coated silver
Megan adjustable upper contral arms , traction rods, and toe arms out back and Megan tension rods in front
SPL solid subframe bushings
SPL Solid Diff Bushings
INTERIOR:
Brand new Stockinteriors.com black carpet
I Imported RHD doors and they are fully functional as well with the power folding mirrors
AEM Tru boost electronic boost controller Set to 12 PSI
AEM Wideband
Gauges are mounted in a angled 1 din pod above the radio
there is no radio in the car. It didnt come with one when i purchased it, i honestly dont listen to it that much anyways so it never bothered me.
Greddy shift knob
B&M Shifter
JDM Recaro steering wheel (came with clip)
S14 Seatbelts
Fully functional JDM Auto climate control (came with front clip)
BRAKES:
Complete z32 brake swap!
Brake calipers and rotors were purchased brand new
30mm powder coated front calipers
Slotted brembo front rotors
Powder coated rear calipers
Brand new backing plates, e-brake shoes and all hardware from Nissan,
Working e-brake!
Ichiba 5 lug front hubs
DRIVETRAIN:
Spec Stage 4 6 puck clutch
Z32 locked diff POR15 black with SPL solid aluiminum conversion bushings
J30 axles
5 lug conversion- z32 rear Brand new Ichiba fronts
oem 2 pc drive shaft
WHEELS:
TE37 Reps
Varstoen
Front- 18x9.5 +12 225/40-18
Rear- 18x10.5 +15 235/40-18
Tires are Falken 512's
TeamMayhem is offline   Reply With Quote
Old 09-04-2012, 11:46 PM   #2
OzzYNMotioN
OzzYNMotioN is an unknown quantity at this point
trade for my sr powered e36?
http://zilvia.net/f/cars-sale/475128...ml#post4886102
OzzYNMotioN is offline   Reply With Quote
Old 09-05-2012, 05:01 AM   #3
subiesean
subiesean's Avatar
subiesean is an unknown quantity at this point
Clean undercarriage love type x's
I change cars too often...
Ho.Mo.Co.
subiesean is offline   Reply With Quote
Old 09-05-2012, 09:02 AM   #4
Typeone
Typeone's Avatar
Typeone has a spectacular aura aboutTypeone has a spectacular aura aboutTypeone has a spectacular aura aboutTypeone has a spectacular aura aboutTypeone has a spectacular aura aboutTypeone has a spectacular aura aboutTypeone has a spectacular aura about
Super clean car. GLWS
Nissan 370Z
WedsSport/BC Racing/Project Kics
Typeone is offline   Reply With Quote
Old 09-05-2012, 10:45 AM   #5
KendallH
KendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choices
Damn this is beautiful... Any interest in trading for a two-tone silvia front coupe? tuned sr, OEM aero bumper, bricks, brand new FA coils, 5 lug, z brakes, HUD, etc?
KendallH is offline   Reply With Quote
Old 09-05-2012, 11:01 AM   #6
RHD_G
RHD_G's Avatar
RHD_G is an unknown quantity at this point
180sx
bump for another rps13 rep ownwer! got the same thing going on down here in florida for sale aswell good luck with sale
RHD_G is offline   Reply With Quote
Old 09-05-2012, 03:55 PM   #7
TeamMayhem
Shoot me a text with some info and pics. Deff interested thanks!
Old 09-05-2012, 04:58 PM   #8
imnotniko
imnotniko is an unknown quantity at this point
interested in a suzuka blue s2000? its in the fs threads.
imnotniko is offline   Reply With Quote
Old 09-05-2012, 11:12 PM   #9
Mofuhcka
Mofuhcka's Avatar
Mofuhcka is an unknown quantity at this point
Other than the stickers on the reps, looks pretty nice!
@hcr32love 400whp NEO R32 Sedan
Mofuhcka is offline   Reply With Quote
Old 09-10-2012, 12:44 AM   #10
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
now THIS is how a for sale thread SHOULD be for a car!!!
free bump for awesome thread!!!
Old 09-10-2012, 08:28 AM   #11
VipIS3
VipIS3 is an unknown quantity at this point
Might be a strange question but how much would you want if you put in a KA?
VipIS3 is offline   Reply With Quote
Old 09-10-2012, 08:45 AM   #12
tricky_ab
tricky_ab's Avatar
Exactly what I was thinking...
Good luck with the sale...
Old 09-10-2012, 09:36 AM   #13
TeamMayhem
This would be up to the buyer to do... It has the whole 180sx wiring in it so putting a KA in it would be going ass backwards in my opinion or "pissing into the wind" as they say.. I dont have the KA regardless, it was sold 3 weeks after i bought the car.
Old 09-11-2012, 01:56 AM   #14
VipIS3
Wish you were atleast on the west coast, your car looks very well put together and free bump for you sir!
Old 09-11-2012, 06:03 AM   #15
TeamMayhem
Thank you, i will ship also. At the buyers expense, i did some quotes for a potential buyer, $600-750 shipped to CA. Shouldnt be to much distance to seattle.
Old 09-16-2012, 08:16 AM   #16
TeamMayhem
Bumb#1 Trades updated.
Old 09-16-2012, 08:18 AM   #17
240dream
240dream's Avatar
240dream is an unknown quantity at this point
saw this car a few days ago, shits mint,and sounds great
240dream is offline   Reply With Quote
Old 09-16-2012, 03:39 PM   #18
xpinoyxmk
xpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura about
If this was lhd, i would sell my car and pick this up. Just not a fan of rhd.
Glws
xpinoyxmk is offline   Reply With Quote
Old 09-16-2012, 04:13 PM   #19
KravingAKouki
KravingAKouki is an unknown quantity at this point
this is clean as hell. Do you have a build thread by any chance?
KravingAKouki is offline   Reply With Quote
Old 09-17-2012, 05:39 AM   #20
va240dude
va240dude's Avatar
Trader Rating: (161)
va240dude is an unknown quantity at this point
Feedback Score: 161 reviews
Looks clean, nice job!
180SXオタクだ!
va240dude is offline   Reply With Quote
Old 09-17-2012, 08:42 AM   #21
naCAnItIhS
naCAnItIhS is an unknown quantity at this point
Trade for 2005 Subaru Legacy GT, 5-spd shiftable automatic, Limited and stage 2 (turboback and tune)?
naCAnItIhS is offline   Reply With Quote
Old 09-17-2012, 12:12 PM   #22
rbsidewayz
rbsidewayz is an unknown quantity at this point
trade for an s14 rb25..???
rbsidewayz is offline   Reply With Quote
Old 09-17-2012, 10:48 PM   #23
hybridcmk
hybridcmk is an unknown quantity at this point
you got pm'ed
hybridcmk is offline   Reply With Quote
Old 09-19-2012, 05:57 AM   #24
TeamMayhem
Thanks, I actually dont, i have about 1,000 pictures so i could. If the car dosent sell in a month, i will paint it and keep the car as well start a thread.
Old 09-25-2012, 08:28 AM   #25
TeamMayhem
All PM's Replied
180sx, kouki, rhd, sr20, sr20det
