08-22-2012, 12:07 PM | #1 |
Electrical issues all suggestions much appriciated!
I just finished my SOHC to DOHC swap about 3 weeks ago. For the last 3 weeks everything was absolutely perfect! No issues what so ever! However, last weekend i took a trip and left my car at home in my garage. When i come back i noticed that my clock in gauge cluster isn't working, so i thought my battery was dead. But the car started with no problems. then i noticed that the cluster acts like it is completely unplugged until about 2 seconds then it starts working fine. sometimes it wont start working until i rev the engine. Yesterday was the first real day of me driving it after the weekend and i noticed the radio shuts off for about 4 seconds randomly. Then when i got home i realized that when the engine is off ALL electronics stop working. the seat belts don't retract, the lights wont turn on NOTHING! And this is with the Key in the ON position... I am absolutely dumbfounded. Any suggestions would be help full. Thanks in advance
Car is a 1990 hatch with a 1996 KA with S13 ECU and Harness. idk if it matters or not... |
08-22-2012, 11:58 PM | #3 |
08-23-2012, 12:14 AM | #4 |
Did the car start once ON switch stop working?
sounds like a loose power wire or ground. a power wire that is dangling and grounds out will jolt the system and pop fuses. take a test light to the fuse box and start poking around. since the problem started at the clock pull the cluster and look for a loose wire |
08-23-2012, 12:21 AM | #5 |
There will be a certain fuse that controls the clock, along with a couple other misc things.
same as the cluster. and every other electronic in the car find the fuse and test that slot for power with a test light. that will help you narrow down if your problem lies between the Input or Output side |
08-23-2012, 12:29 AM | #6 | |
08-23-2012, 12:42 AM | #7 |
i'd just look for bad fuses, and then check relays but usually i have narrowed all my wiring issues by tracing wires that were incorrectly wired and finding multiple fuses blown bc some fuses depend on each other and will continuosly blow out until all fuses are replaced.
08-23-2012, 11:04 AM | #8 | |
Easiest way is to find a schematic and see which wire from the ignition switch powers the accessories. with the test light, look for the popped fuse . test the fuse socket (input Side) If the light Lights up then you know you have good power from the input side, and your problem lies within the Output side. you can even just test the ignition switch itself with the light, turn it onto the "on" position and start poking around to see which light up and which ones don't Its there to help you narrow down the where the broek wire is. |
08-23-2012, 11:48 AM | #9 | |
08-23-2012, 07:06 PM | #11 |
Can't get too much power. You'll get too much amperage. Most likely a short to ground. Wire could be bare and grounding out before the load and causing too much current to flow. Best bet is to put a circuit breaker on whichever fuse blew and start tracing wires.
-Victor S. |
08-23-2012, 07:33 PM | #12 | |
the light will let you know if you have a wire thats broken. it could have broken, but in the process grounded it self out causing a short. You can also you a multi meter an check the volts as well. |
08-23-2012, 07:35 PM | #13 | |
just start poking around with a light and multimeter |
08-23-2012, 07:39 PM | #14 |
Since your alternator fuse also popped, you should check the lower harness for any rubbed and exposed wires, as well as a loose ground/power wire. in the engine bay.
Could also be a bad alternator over charging. |
08-23-2012, 07:56 PM | #15 |
I know that if your Gauge cluster and radio are cutting out it can be the ecu, try wiggling the plug and see if anything comes back on, I had the same issue before.
08-23-2012, 10:47 PM | #16 | |
He can't test an open circuit. Circuit breakers are a godsend when it comes finding shorts in the system.
-Victor S. |
08-23-2012, 11:03 PM | #17 |
since that fuse only bridges X amount of things. he should what it bridges.
pull that fuse, stick a multi meter into the input side and and see what it comes back with. |
08-23-2012, 11:07 PM | #18 |
fix the problem before putting the fuse in, simple as that.
thats what a multimeter and test light are for. if its popping so quickly a circuit breaker wont do anything since it will just trip as soon as the car is powered on. and to add a higher amperage circuit breaker would be dumb as well, since that would just give you a good chance at an electrical fire. |
08-27-2012, 01:55 PM | #20 |
Hey guys, thanks for all your help. i found the problem. i had 2 bare, loose wires that made contact with the alternator and caused a short. Fixed the wires, replaced the fuse, now it runs fine.
