08-01-2012, 10:39 PM | #1 |
garage clean out s13/s14 sr/ka /lightweight flywheel oversized isis oil pan
s13 parts
driverside door lock mechanism $20 front door speaker plastic brackets $10 auto seatbelt computer $5 door dinger unit (for when door is open it makes a noise) $5 Dual cam HUD cluster sub harness $20 hatch rear wiper buttons $5 Rare Discontinued Trust Greddy Pe2 stainless steel catback. It was only sold in japan and is basically a stainless version of a Ti-C. Also same thing as the new Greddy exhuast that just came out but with a angled exit tip. 80mm pipping to 120mm tip sounds beautiful deep and quiet unless WOT. some small scrapes on canister nothing bad or dented and only used for 3-4 thousand miles $400 s14 parts front loaded calipers with stock pads about 60-70% life left and mounting brackets (good upgrade for s13 front) $50 zenki headlights missing some tabs $40 for both rear spindle $10 clean red zenki humper no lights $50 Ka parts s14 head without cam caps $50 s14 IACV with one broke sensor $20 s13 TPS $20 water pump $30 s13 ignition coil $20 motor mounts with some little reinforcments welded on $40 2x s13 p/s pumps $40 each p/s pump bracket $15 alternator bracket $5 s13 intake mani w/ all sensors $60 oil pan $30 clutch fan $15 s13 clutch fan shroud $15 sr20det redtop parts sr alternator $50 complete intake manifold with all sensors incl new oem IACV $150 another intake manifold with no throttle body, but with iacv $50 fuel rail with 3 370cc injectors and fpr (one has a chipped plug but still works)- $50 water pump $30 water pump pulley $10 front cover (needs new oil pickup) $30 crank pulley $15 cas x2 $75 each coil packs + harness $100 stock pistons and rods (one rod has a spun bearing) $40 thermostat housing $20 water jacket $15 dust plate $30 alternator + bracket $70 speed sensor $50 almost new (40 miles if even) ACT lightweight flywheel $200 oversized almost new (40miles if even) isis oil pan $100 more pics soon |
08-07-2012, 03:40 PM | #3 |
pics of the isis oil pan
10-03-2012, 05:18 PM | #6 |
I'll buy the SR20det main crank pulley off you as long as its not damaged. please lmk if your willing to ship to 96817.
Jhony 808-253-9464 text me or call thanks. PayPal ready!
1989 Nissan 240SX SE SR20DET project! |
