Old 07-14-2012, 07:33 PM   #1
HellaSexyS13
HellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-known
s13 sticky clutch pedal
just got my 93 coupe on the road, has a s14 sr20 swap, has a spec stage 3 clutch and flywheel
the clutch pedal engages and disengages by only pushing the pedal down maybe an inch or so, but if you push the pedal down all the way it sticks for a second and comes up slowly.
any ideas what is causing this? i may try bleeding the slave cylinder again.
HellaSexyS13 is offline   Reply With Quote
Old 07-17-2012, 06:28 PM   #2
XSB1X
XSB1X is an unknown quantity at this point
might be a bad slave cylinder
XSB1X is offline   Reply With Quote
Old 07-17-2012, 07:10 PM   #3
7jpat
7jpat is an unknown quantity at this point
mine dose that to but i have to pull it up with my foot , but drives fine , its a sohc
7jpat is offline   Reply With Quote
Old 07-17-2012, 07:18 PM   #4
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Put a new master and slave cylinder
Old 07-18-2012, 11:16 AM   #5
hooopla
hooopla's Avatar
hooopla is an unknown quantity at this point
I had the same problem in my car, didn't do anything about till my clutch took a dump, took the tranny out to notice the spring retainer on my clutch fork was barely on. Might wanna look into that
hooopla is offline   Reply With Quote
Old 07-18-2012, 03:01 PM   #6
HellaSexyS13
replaced the clutch master and slave cylinders, feels good now
Old 07-18-2012, 10:26 PM   #7
n33sanz
n33sanz is an unknown quantity at this point
Did you have any major difficulties bleeding the clutch??? Do you have the dampner removed? I am in the process of this now. Once I get my tranny back in I have to change the slave. Hoping it does the trick. I have to pull mine up a lot too as it just sinks to the floor. Clutch doesn't slip at all tho.
n33sanz is offline   Reply With Quote
Old 07-18-2012, 10:31 PM   #8
future
future's Avatar
Trader Rating: (42)
Good job
Glad you got it going
Old 07-19-2012, 07:46 AM   #9
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
having the same issue..thansk for the help let me see if that works...
Old 07-19-2012, 03:43 PM   #10
HellaSexyS13
yea i took that damper off a while ago, its pointless, just installed the new master and slave, pumped the piston on the slave by hand a bunch of times until no more bubbles came out of the master, need someone to watch it, then bleed it the normal way with the bleeder valve and pressing the pedal
240sx, clutch, pedal, sr20, trans
