Old 07-11-2012, 07:02 PM   #1
TC2SR
TC2SR is an unknown quantity at this point
oil leak on sr20!! where is it coming from?!?
I have a redtop sr20 and its been leaking oil alot lately. I check the oil pan, the oil filter, my oil pressure sensor outlet, and valve covers and i dont see any leaks anywhere. However, after driving my car hard a bit for a few days, i would see droplets of oil clinging to my oil pan and my front sway bar dripping with oil as well. I dont know where the oil is coming from. I THINK it might be the crankshaft seal leaking but i dont know for sure. anyone have any ideas?? (
TC2SR is offline   Reply With Quote
Old 07-11-2012, 09:12 PM   #2
Prozac
Prozac is an unknown quantity at this point
Depending on how clean you keep your engine , it should be somewhat easy to determine where its coming from , Could just be misting and building up and slowly creating a leak. Really need more info to help determine what area it is coming from , again which a clean engine you should be able to find out at least what region it is coming from.
Prozac is offline   Reply With Quote
Old 07-11-2012, 09:16 PM   #3
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
I would def look into the front main seal...
Driftphreak87
Okinawandrifter87 is offline   Reply With Quote
Old 07-12-2012, 06:58 PM   #4
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
front main seal, head gasket, front cover.
godsmack is offline   Reply With Quote
Old 07-13-2012, 09:22 AM   #5
Gutling
Gutling is an unknown quantity at this point
I had oil on my sway bar when my front seal was bad. pulley was slinging it. use a mirror and flashlight and peak behind crank pulley
Gutling is offline   Reply With Quote
Old 07-13-2012, 11:33 AM   #6
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
I had a bad front main seal and it was slinging oil on my sway bar, upper radiator hose and on my hood, lol. Basically anywhere in the rotational plane of the pulley.
Old 07-13-2012, 10:19 PM   #7
TC2SR
yea, its the front main seal guys. I just took a look after i cleaned the area underneath the crank and i see oil streaks. already bought my seals so ill be fixing it soon. thanks again!
leak, oil leak, problem, sr20, tech
