Old 06-16-2012, 11:21 AM   #1
CharCharXD
CharCharXD's Avatar
CharCharXD is an unknown quantity at this point
Question Auto KA to Manual SR swap?
What are some things I need to do this swap? Does the auto ka driveshaft work for a 5 speed sr? & Where can I find the parts? Thanks in advanced.
CharCharXD is offline   Reply With Quote
Old 06-16-2012, 11:37 AM   #2
92SEric240sx
92SEric240sx's Avatar
Trader Rating: (32)
92SEric240sx is an unknown quantity at this point
Feedback Score: 32 reviews
To to a junk yard I'f your sr is already with a 5 speed you will need a manual driveshaft, clutch pedal, clutch master and slave cylinders, 5 speed crossmember, shifter. Run a brake line from the master to the slave cylinder
RELAX BRO!!!!
92SEric240sx is offline   Reply With Quote
Old 06-16-2012, 11:47 AM   #3
Nickys13
Nickys13's Avatar
Nickys13 is an unknown quantity at this point
Brake pedal, clutch master cylinder... Then if you don't want to die from fumes, a shift boot... and don't forget you have to jump two wires that tells your car its always in park so it starts because its an auto chasis.
Try doing research instead of starting a thread bro. Auto to manual isn't a new thing.
Nickys13 is offline   Reply With Quote
Old 06-16-2012, 11:55 AM   #4
Silentoreo34
Trader Rating: (28)
Silentoreo34 is an unknown quantity at this point
Feedback Score: 28 reviews
240sx manual transmission swap
ppl part out cars all the time on here and also sell the the kit as a whole.
Silentoreo34 is offline   Reply With Quote
Old 06-16-2012, 11:56 AM   #5
240zach
240zach's Avatar
240zach is an unknown quantity at this point
yeah all you need is clutch master, clutch pedal, brake pedal ( you can cut your auto one and it will be fine) and clutch hardline, then u can just delete the clutch damper box by running hardline to soft line, then a ds and your good.
and you want that rubber boot and metal ring. its so nice to not have a hole in your cabin to where you can stare at the ground. lol
240zach is offline   Reply With Quote
Old 06-16-2012, 08:55 PM   #6
overpaid4myfc
overpaid4myfc has made poor choicesoverpaid4myfc has made poor choicesoverpaid4myfc has made poor choicesoverpaid4myfc has made poor choicesoverpaid4myfc has made poor choicesoverpaid4myfc has made poor choices
it shouldn't be that bad, just make sure you have all the right parts
overpaid4myfc is offline   Reply With Quote
auto, ka24de, manual, sr20det
