06-05-2012, 09:52 PM | #1 |
96 zenki SE clean title 139k **cheap**
i have had this 96 zenki for a year and a half now.its a auto converted to maunal.i got it like that from the previous owner in west covina.iv been fixing this car trying to get it smog but I'm tired of putting money and time in this car.so I'm letting it go for cheap AS IS! my loss is your gain.if you want a project car,or gonna swap the motor this is the car for you.located in San Diego and its first come first serve.
$2500 OBO Pros: Clean title SE model 5lug fogs lip clean interior uncracked dash upgraded pulleys Memphis audio speaks in doors alpine type-s speakers in rear has sub wiring(but the RCA cables) 139k on motor unknown brand engine strut Short shifter Trunk is completely covered in phat mat Parts iv replaced: front windshield driver window regulator(notorious) driver door lock actuator secondary O2 sensor knock sensor fuel pump fuel filter 1 injector IACV Entire distributor spark plug wires spark plugs rear interior panels(previous owner had holes in them because he ran speakers in them) front and rear struts/springs(previous owner had the car lowered with cut springs rear and blown megans in front) stock exhaust(had fart can from previous owner) Cons: *Front end damage,hood bent at the tip,pushed in grill,broken passenger headlight tab(pics will show damage) *Could use paint.car was originally blue/purple but owner painted it black which is peeling and fading *Needs new CAT *Has CEL for: EGR flow malfunction trans position range sensor(using a manual ecu will get rid of this) Crank position sensor malfunction *Backed registration *2 broken wheel studs(have no ones just not installed) *driver door panel missing
Life is like a box full of shenanigans Last edited by 8Nismo9; 06-07-2012 at 11:59 AM.. |
06-08-2012, 10:46 AM | #8 |
Serious and Interested. So other than few sensors and and cat converter...how is the motor? Is it the original motor for the car or a swap?
06-08-2012, 02:23 PM | #9 |
Motor is perfectly fine.orginally motor and reg is backed up since 2010.if no one buys the car soon I'm gonna sell it to Carmax
Life is like a box full of shenanigans |
