![]() Hi everyone,
i already got a nissan silvia s15 with rb25 swap, well this car has some aftermarket stuff such as Intercooler, 3'' IC piping, 3'' lines, .44mm WG, cometic head Gasket, haltech e6X (i assume is ussing batch injection), GT35r, Walbro 225, but stock injectors. Right now its boosting 15 psi (16 peak), is this a safe boost press for stock inj? how much boost can stock inj support (on GT35)? aprox how much RWHP can i make?, because right now i think is 320 - 340 aprox (i think is a little low for this turbo at 15psi). Hope someone can help me. Regards Last edited by rpanaque; 05-27-2012 at 09:50 PM.. |
#5 |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
Do you have a wideband? If so, what are you afs? If not, get one immediately, check your afrs, then think to yourself if they are safe or not. If not, get bigger injectors and go get a tune.
#6 |
![]() Join Date: Aug 2010
Trader Rating: (43)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 43 reviews
Stock RB25 injectors are 370cc, I know 370cc injectors max out around 250whp on a SR20, my guess would be around 300whp for a RB25. You will run out of fuel very quickly, do you have a wideband?
#7 |
My wideband is on the way ,hope to get it this week, hope everything going well because i dont know how many miles (street, track) the last owner drive with this configuration. As soon as i get the numbers i will post it (i think is not going to be good but just wait). Thanks
#8 |
![]() Join Date: Dec 2007
Trader Rating: (38)
![]() Feedback Score: 38 reviews
You need to do your own research. We all learn by searching. Look at other RB builds and learn that way. Your never gonna learn if you keep getting answers handed to you.
#9 | |
Thanks all for your time, as soon as i get the result i will post it (in order to help others). |
#10 |
Man w/ CTSV & a Car Seat
370cc injectors...good rule of thumb on RBs is that 1cc injector = 1hp. So stock injectors are hypothetically good enough to support up to 370 hp. Now, how the tune is, is a different story. I'd leave it alone unti you some bigger injectors. You should be able to hit 550-600hp on an RB with that turbo. So go get bigger injectors.
boost, gt35r, rb25, swap |
