05-17-2012, 01:25 AM | #1 |
s14 vacuum lines under the throttle body, where do they go!!!
hey i got a 97 kouki, it used to be kat but it blew so i got a 91 ka (trying to go back to stock so i can pass smog) i swapped over the manifolds, emissions, etc. now im at the throttle body and i cant i cant figure out where theses lines go.
05-17-2012, 01:28 AM | #2 |
i believe 2 connects to three ( those are the coolant passages). Im not sure where 1,4 and 5 go. doesnt one of theses connect to the intake pipe?
any input would really help me out. thanks |
05-17-2012, 06:00 AM | #3 | |
EDIT: The vacuum drawing is on EC-10, but it doesn't show the TB in very clear detail. |
05-17-2012, 09:28 PM | #4 | |
yes my friend, i wouldnt have posted if i hadnt check the fsm, nico, zilvia, google etc. its highly unclear in the fsm. which is why im asking. & i took the time to post and edit pictures. |
05-19-2012, 06:10 PM | #8 |
Do a better search, I personally have covered this quite a few times in the last year.
05-20-2012, 04:27 PM | #9 | |
My friend, i have checked all your post and topics created (last 500) all you have is SR vacuum diagram material. please dont waste my time if you wont take the time to read my thread, or post usefull info. |
05-20-2012, 06:19 PM | #11 | |
1. Unsure of at this time. 2. I believe goes to the IACV? 3. Is your coolant inlet/outlet for the throttle body 4. Is not a vacuum source, you can cap it. 5. Is a vacuum source
*My SR20VET* Does your VTC gear rattle in your S14/15 SR? PM me. Last edited by jr_ss; 05-20-2012 at 06:57 PM.. |
05-20-2012, 10:06 PM | #13 | ||
ok, thank you for the input. 2 goes to 3. im still uncertain about 1,4 and 5. i dont want to cap anything off, because i have all the stock parts, and am going back to stock. and it seems as if you guys are uncertain about 1,4,5. doesnt one of theses connect to the plastic intake pipe? if so which one? also i dont think anyone of these lines connect to the iacv or egr evap, because all thoses sit on the back of the engine and i have all those vacuum lines sorted out. there are no missing connections in the back of the engine. though these might travel from front to back i still need to know where they start. once again, thank for the input, hopefully we can get this solved. |
05-21-2012, 04:13 AM | #14 |
I'm pretty certain that 1 and 5 run over to charcoal canister on the drivers front side. That needs atleast one vacuum source which could be either one of those two. 4 is not a vac source because it is before/at the throttle plate, it may connect to the black plastic intake pipe right before the throttle body. It's been awhile since I've messed with a KA.
05-21-2012, 02:37 PM | #16 |
Im too lazy to take all of it apart but I felt where 1 goes to and i think it goes to 4 unless there is another connection on the front (side closest to bumper) of the throttle body
05-21-2012, 11:58 PM | #17 | |
my friend. its a 97 obd2. not a 95,96. the gas tank emissions etc sit behind the passanger rear wheel. once again, please read my thread instead of just posting. but i thank you for the input. |
05-21-2012, 11:58 PM | #18 |
big thanks to strider hiryu for helping me out. actually taking the time out to pop his hood and check. great guy. also thanks to all the people who gave input.
so its done. 1 goes to 4 2 goes to 3 5 goes to small intake. i hope this helps out someone in the future! |
05-22-2012, 04:31 AM | #19 |
I read the thread, I had no idea that the charcoal canister was moved/removed on the 97-98 models.
