Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Advertiser Announcements and Feedback
Advertiser Announcements and Feedback This is where vendors can make announcements about upcoming promotions, events, items, etc. Vendors may also create threads here for the purpose of market research or other customer feedback.
Old 04-25-2012, 07:28 PM   #1
Thorough Concepts, LLC
Thorough Concepts, LLC's Avatar
Thorough Concepts, LLC is an unknown quantity at this point
Cool Why use a Thorough Concepts High Pressure Power Steering Setup??
Why would you want to keep the use of your sensor on your high pressure power steering setup??
Here's why!
Check out our high pressure power steering setup with our patented distribution block to retain the use of the stock sensor along with our other products at:
Our Retail Store
For more information on who we are and what we do, check out:
Home - Thorough Concepts, LLC
Thorough Concepts, LLC is offline   Reply With Quote
Old 04-25-2012, 07:54 PM   #2
S13x88
S13x88 is an unknown quantity at this point
Are there any plans to sell that distribution block? My sensor is fine and I still have some left over braided hose. All I would need are the fittings.
S13x88 is offline   Reply With Quote
Old 04-25-2012, 08:15 PM   #3
GeneStarWindGSW
GeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant future
Originally Posted by S13x88 View Post
Are there any plans to sell that distribution block?.
x2, interested in the distribution block as well
http://zilvia.net/f/showthread.php?t=637070 last of my parts f/s
GeneStarWindGSW is offline   Reply With Quote
Old 04-26-2012, 12:21 AM   #4
Wake
Wake's Avatar
Signs me up for a distribution block too. Lol
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 04-26-2012, 08:27 AM   #5
fullthrottle
fullthrottle's Avatar
fullthrottle is an unknown quantity at this point
So this idle up is going to help my steering while im bouncing my car off the rev limited? Maybe i dont understand.
fullthrottle is offline   Reply With Quote
Old 04-26-2012, 08:59 AM   #6
snafupossum
snafupossum is an unknown quantity at this point
You'r not always going to be bouncing off your rev limiter at full lock.
snafupossum is offline   Reply With Quote
Old 04-26-2012, 09:13 AM   #7
DavidEspiau
DavidEspiau is an unknown quantity at this point
That's a clean looking little setup ya got there. How much?
DavidEspiau is offline   Reply With Quote
Old 04-26-2012, 10:31 AM   #8
dkim1985
dkim1985's Avatar
Trader Rating: (28)
dkim1985 is an unknown quantity at this point
Feedback Score: 28 reviews
also interested in just the block. how much?
i have the chasebays powersteering setup. would the block be compatible with that?
FS: Nismo R-Tune Camshafts for VQ35DE.
dkim1985 is offline   Reply With Quote
Old 04-26-2012, 11:24 AM   #9
iamtheyi
iamtheyi's Avatar
iamtheyi is an unknown quantity at this point
lol I must be retarded because I read it four times and still don't get it. Can someone tell me what this is in layman's terms?
iamtheyi is offline   Reply With Quote
Old 04-26-2012, 11:50 AM   #10
DavidEspiau
It's just saying that we should keep the sensor so our cars won't bog down at full lock when our rpms are low. Basically this sensor sends a signal to bump up the idle during full lock to reduce strain on the motor.
Old 04-26-2012, 01:01 PM   #11
Thumbs up
(Thats the closest I could find to a thumbs up lol) And that is exactly right. I should have added a brief explanation which is my bad.
Old 04-26-2012, 01:04 PM   #12
To everybody looking to buy the sensor and the fittings, YES! We will be selling just the power steering block and appropriate fittings. In fact we're going to go ahead to get it done extra quick based on the interest in this thread. When we do (which should be within the next couple of days) we'll be posting both back on this thread, as well as on the front page of zilvia.
Old 04-26-2012, 01:33 PM   #13
To my knowledge it is not directly compatible (we will certainly look further into it), however as with anything, it comes down to hose lengths, fittings, and ends.
If anybody has already tried tweeking their Chase Bays setup to be compatible with ours let us know what you find!
NOTE: to my knowledge the Chase Bays kit is simply a replacement setup with an aluminum reservoir and not a full high pressure system (see here). Our system is a full high pressure setup using all stainless steel braided, teflon inner coated lines as well as high pressure fittings with o-rings and all appropriate fittings are pre-installed with teflon paste into the distribution block to the correct torque specifications. We also test-fit all setups before shipment to triple check quality and fitment.
Old 04-26-2012, 01:42 PM   #14
We're currently selling the full base setup for $219.99 on our retail store here.
You can check out more details and pics here!
Old 04-26-2012, 02:21 PM   #15
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
you should have the option to not run it also, maybe more people would jump on it.
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
Old 04-26-2012, 03:34 PM   #16
S13x88
Awesome! Thanks a bunch, I thought I was the only one :P
Old 04-26-2012, 07:03 PM   #17
INeedNewTires
INeedNewTires's Avatar
INeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond repute
would a PowerFC or AEM EMS take the sensor into account? do they even see it? do they care?
INeedNewTires is offline   Reply With Quote
Old 04-26-2012, 08:21 PM   #18
Thumbs up
Basically any vehicle specific, plug and play system should account for all factory sensors unless configured otherwise i.e. race applications.
Old 04-27-2012, 02:47 PM   #19
matts13vert
matts13vert's Avatar
Trader Rating: (31)
matts13vert is an unknown quantity at this point
Feedback Score: 31 reviews
I hope you realize that this block is useless for anything other than having the OEM idle bump. It will not affect anything when the throttle is open i.e. normal driving, time attack, drift, whatever it may be.
Most small 4 cylinder engines do not produce enough power at idle to compensate for the power loss caused by the pump which is why that sensor is there, it bumps IDLE speed to keep the engine from bogging down/stalling.
Its the same reason the idle is bumped up when you engage the A/C the compressor.
Only situation i see this being functional is if your off throttle long enough for the engine to come down to an idle, and car is at full lock.
matts13vert is offline   Reply With Quote
Old 04-27-2012, 04:13 PM   #20
Wink When would the block be useful?
You are absolutely correct in the function of the sensor! That is indeed exactly what it does. Which, as you stated, is very useful in situations when "your off the throttle long enough for the engine to come down to an idle, and the car is at full lock".
When would such a situation occur?
1) Downshifting or e-braking in drift/competition scenarios. You would be in a little bit of trouble, for ex., if your car died going into the downhill section of horse thief at our upcoming competition! (June 2nd AND 3rd, signup here!)
2) Parallel parking during everyday street driving. Not everybody's car is purely for competition and they may be fine with deleting the sensor for their track car (which we do NOT recommend) but it's certainly a useful thing to have on a daily driver as well.
You are correct in the idle being bumped for the A/C which at the fundamental level is an accurate comparison. But people should remember that although the function (of bumping the idle) is the same, the load types are different. The A/C being a constant load, and one that is generally not seen on the track. (Not arguing with your comparison, just adding a note for readers)
Additional benefits of our system and would be the actual position of our High Pressure lines. We route them the same as the OEM lines which serves multiple functions:
1) Keeps the lines cooler than other systems that delete the sensor and run the lines close to the exhaust (additionally we thermal sleeve the line for a bit of added protection)
2) Longer lines result in cooler fluid. It can be argued how much cooler, but cooler nonetheless.
Thanks for helping us educate readers about our product and how it functions
Additional details can be found on our website here! And be sure to check out our retail store here! where you can both purchase product AND signup for our upcoming event. Hope to see you out there!
Old 04-27-2012, 04:34 PM   #21
Sugoi_Style
Sugoi_Style's Avatar
Sugoi_Style is an unknown quantity at this point
That was thoroughly indepth, thanks Matt and TC LLC.
Sugoi_Style is offline   Reply With Quote
Old 04-27-2012, 04:54 PM   #22
Cool
Ask and you shall receive! We have now listed for sale our patented distribution block with fittings and all necessary hardware for $62.99!
Buy it HERE!
NOTE: photograph is shown with optional stainless steel lines + optional OEM sensor. These are not included in this newly listed product.
We'll be posting this great news on the zilvia front page shortly.
Old 04-27-2012, 07:14 PM   #23
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
so are you guys thinking of making some without the sensor?
- Hong
Old 04-27-2012, 10:19 PM   #24
Thumbs up
Yea in the sense that we'll sell the block and the lines separately, but as of now we don't have plans to sell a setup of lines that delete the sensor. There are plenty of companies out there selling that and we believe in our product. We may revisit the idea if we find additional ways in which we can improve upon what's currently out there on the market, that's just who we are and what we do! If we're gonna make something, then it has to be the best out there no matter what it is.
Old 04-28-2012, 08:59 AM   #25
hellion240sx
hellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enough
did anyone find out if this is compatible with the chase bays power steering set up?
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE!
240 addict miata addict
hellion240sx is offline   Reply With Quote
Old 04-28-2012, 05:41 PM   #26
dkim1985
dkim1985's Avatar
Trader Rating: (28)
i would like to know this too.
tc, i couldn't find fitting sizes on your website.
chasebays hp fittings are -6AN.
i have the chasebays kit..but would like to include this block.
looks like someone in my position would need the block and an extra line(?)
Old 04-29-2012, 04:44 AM   #27
Wake
Wake's Avatar
It should work with chasebays, given you have the right fittings.
This isnt rocket science people.
S.P.P.S. Member #00
Old 04-29-2012, 11:46 AM   #28
dkim1985
dkim1985's Avatar
Trader Rating: (28)
^not helping
obviously it will work with the right fittings, which is what we're trying to find out.
Old 04-29-2012, 11:33 PM   #29
Hi all,
The fittings (line side) are dash 6AN.
In response dkim1985, yes you would need another line in order to incorporate the block into the existing chase bays setup.
Thanks for the interest and apologies for the late response!
Old 04-30-2012, 08:56 AM   #30
hellion240sx
Basically you need tyhis to work with the cb kiy correct?
HPPS Setup for Nissan 240sx '91-'02 + Power Steering Rack Bushings
drifting, power steering, race, steering, thorough concepts
