Fuel injectors not firing??
Does anyone know where i can find the wiring schematic for the fuel injection on a 91 240 with ka24de??
I've been working on getting my car running and fixed everything but my fuel injectors will not continue firing. They will only give off first initial spray. Fuel pressure seems good all the way up to the injectors. I'm thinking it has to be a wiring issue. If anyone can let me know where the wiring diagram is I would appreciate it. I cant seem to find one. |
First initial spray - i.e. the priming pulse before you even crank the car?
Make sure your dizzy/cas signal is hooked up right and all of your harness grounds are secured properly. |
ok just to update.
I had checked all my harness and fixed any exposed wires and cleaned grounds, ECU is good. Ended up with good spark, good fuel pressure but no fuel past injectors. My Crank Angle Sensor had gone bad. Its in the Distributor. Replaced Dizzy and car finally fired up first try. |
#5 |
kouki man
![]() Join Date: Apr 2006
Trader Rating: (36)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 36 reviews
turn your ign on (dont crank) then check for voltage from each injector clip. you probably not getting power to your injectors thats why they are not firing. should get 12v. you need to trace a red wire.
#6 | |
It was distributor. Fixed now. |
cranks, fuel, injectors, start up problems |
