Old 03-14-2012, 04:23 AM   #1
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
s13 Multiple Part Outs + S14 5 Lug, 5spd, Endless, Brembo, Project Mu, DSS + MORE!!!
Updated Jul 31 2012 12:50pm
Located:Oceanside and Orange County
If You Need It, I Probably Have It(Mainly S13)
Parts are continuously listed, if you dont see it ask me.
WTB Hicas Front Steering Rack
S13 Greddy Ti-C Cat Back Exhaust System $450obo
S14 Peak Performance Brand New Front 5 Lug Hubs Comes w/ Studs and NTN Japanese Bearings $200
NRG Green Quick Release Ver. 3 $150obo
S14 Swift Sport Springs Brand New In Box $150
S13 Front Tein S Tech Cut Springs $40obo
S13 Manual Side View Mirrors $50
S13 Power Side View Mirrors $65
A Lot of Doors(No Dents) $35-$60ea
Juniper Green Driver and Passenger
Black Driver and Passenger
Burgundy Passenger
Passenger Side White Pignose Fender $85
Primer Black Driver and Passenger Pignose Fenders(Have small holes drilled for side skirts) $80ea or $150both
Passenger Side Red Pignose Fender$85
Brand New Aluminum 12x1.25 Lug Nuts for 4 lug(Made In Japan) $35
S13 Passenger Power Window Switch $20
Power Window Amp (Working Condition) $30
S13 Battery Terminal Harness $60obo
75amp Alternator Fuse $15ea
30amp Green or 25amp Orange Fuse $5ea
S13 Dome Light $12
S13 Rocker Panel Interior Floor Trim Pieces $15both
S13 Hatch Black Headliner Trim Strip Piece $10
S13 Steering Wheel Cover Trim pieces $15
Clean S13 Radio Brackets w/ Din and 4 Radio Screws $30
S13 Radio Trim (All tabs in tact.) $30
S13 Steering Wheel Undertray Trim Piece $20
S13 Kick Panel $15ea
S13 Turn Signal Switch Stalk(Low Beam does not flip up headlights, But High Beam Does, Everything else works perfect) $20
S13 Ash Try $15
S14 Grey Driver Seat $130
S14 Manual Front Seat Belts $75
S14 Steering Wheel w/ Airbag $125obo
S13 Back Seat Fabric Dyed Black $40obo
S13 Manual Door Panels Upholstery Removed $50obo
S13 Manual Door Panels $65obo
S13 Black A Pillars Trim $25
S13 Hatchback Black B Pillars Trim$25
S13 Hatchback Black C Panel Trim $25
S13 Hatch Rear Carpet Trim Pieces $15ea
Steering Column w/ Key $70 w/o ignition cylinder $50
S13 Pop Up Hood $60obo
Chuki Bumper Vents $8ea $15 pair
Pignose Front Bumper Foam $15
Coupe Rear Bumper Support $30
Coupe Rear Bumper Foam $10
300zx BM50 Tokico Master Cylinder $100obo
Q45 Front Brake Calipers w/ Rotors $75
S14 Used 5 Lug Front Rotors $30
S13 Professionally Reinforced Clutch Pedal $SOLD
S13 Manual Brake Pedal $45
S13 Gas Pedal $10
S13 Auto Brake Pedal $10
S13 Stock Shifter $15
Stock SR20DET Intake Manifold Comes with whatever in picture, No IACV, No Throttle Body $50obo
S13 Hatch No Holes No wiper and Good Glass $120
S13 Pop Up Headlight Brackets $40
S13 Pop Up Headlight Black Plastic Shroud $30pair
S13 Complete Pop Up Headlight Assemblies $80
Hatch Tail Lights $50obo
180sx Tail Light Garnish $75obo
S14 Passenger Side Zenki Headlight $75
S14 Passenger Side Clear Corner Light $25
S14 Driver Side Clear Corner Light(Broken Tab) $15
H4 Housings $40
Tension Rod Brackets $20ea $35pair
S13 Knuckles/RLCA/RUCA/Toe/Traction with Energy Suspension Bushings Installed $250obo
S13 Rear Hub/Knuckle/RLCA/RUCA/Toe/Traction $85
S13 Rear Lower Control Arm $20ea or $35pair
S13 Rear 4 Lug Hub $15ea or $20pair
S13 Rear Knuckle $15ea
S13 Rear Upper Control Arms $15pair
S13 Rear Toe Arms $15pair
S13 Rear Traction Arms $15pair
S13 6 Bolt Axles $40pair
S14 Stock Traction Arms $20pair
S14 Stock RUCA $25pair
S14 Stock Toe Arms $25pair
KA24DE DOHC Polished Thermostat Housing $30
KA24DE DOHC Polished Front Upper Engine Cover $45
License Plate Bulb Harnesses $10
S13 Coupe Quarter Glass $60ea
S13 Hatch Quarter Glass $65ea
S13 Gas Tank $75obo
S13 Stock Coolant Resevoir Tank(Patched w/ Resin) $25
S13 Clean Stock Coolant Resevoir Tank $35
S13 Above Fan Shroud Intake Tube SOHC $20
S13 Air Box $20
S13 Windshield Washer Bottle $10
S13 Above Fan Shroud Intake Tube DOHC(broken bung) $15
Clutch Fan $25
SPAL Electric Fan $40
SOHC KA24E Header $100obo
S14 KA24DE Cat Downpipe $60
S13 KA24DE Downpipe $20
S13 Manual Window and Regulator $25ea or $40 for both
S13 Power Window Regulator w/ Glass $40
S13 Hood Hinge $5ea
Alternator $30
S13 Rear View Mirror $15
Radiator Cap $3
Hazard, Defrost, Cruise Control etc.. Buttons $5ea
Power Steering Banjo Fitting Adapter Neck Brand New in Nissan Box($56 Retail) $35
S13 Green Wiper Box $10
S13 Brand New in Box Front PBR Non ABS Deluxe Plus Organic $40
S13 Fender Extension Brackets $10ea
S13 Sway Bar Brackets $5ea
S13 Glove Box Bracket $4
S13 Hatch Speaker Brackets $5ea
S13 Steering Rack Brackets $8
S13 Exhaust Hanger Bracket $10
S13 Battery Tie Down Bracket w/ Hooks$15
S13 Rear Seat Hook Bracket$8pair
S13 Rear Subframe Triangulation Bracket $20pair
S13 Rear Seat Hinge $5ea
Almost Complete AC system from SOHC
S13 Power Steering Resevoir $20
S13 E-Brake Handle Assembly $20
S13 Wiper Motor $10
S13 SOHC Power Steering Pump $30
S13 SOHC Power Steering High Pressure Hose $40obo
S13 Hood Prop Bar $10
S13 Gas Tank Straps $10ea
S13 Antenna Harness $20
S13 Power steering Hoses $5ea or less
S13 Door Weatherstripping $15ea
S13 Black Door Trim Seal $15pair
S13 SOHC Throttle Cable $10
S13 DOHC Throttle Cable $20
S13 Hood Latch Cable $30
S13 Dead Pedal $5
S13 Charcoal Canister $5
S13 Fuse Box Covers $5-$15 depending on condition
S13 SOHC MAF $30
S13 Door Striker Plate $10ea
S13 Gas Latch Trim $10
S13 Coupe Trunk Hinges w/ Spring Rods $15
S13 Coupe DOHC Automatic Body Harness $100
S13 Hatch SOHC Automatic Body Harness $100
S13 Stock Rear Sway Bar $10
S13 Stock Front to Back Fuel and Brake Lines $20
Fuel Pump Wiring Cover Piece $5
Auto Transmission Crossmember $15
Dash Support Frame $15
Seat belt parts(ask which parts and make offers)
S13 Passenger Seat Grey Dirty $5
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline
Old 03-16-2012, 12:37 PM   #2
Vatche
Vatche's Avatar
bump for constantly adding parts. i own too many 240's right now...please help me clear out my garage. i dont have the room for this but i love 240's!
Vatche is offline
Old 03-16-2012, 12:39 PM   #3
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Sell me some s14 lower control arms
future is offline
Old 03-16-2012, 01:04 PM   #4
Faztkarvroom89
Faztkarvroom89's Avatar
Faztkarvroom89 is an unknown quantity at this point
PM sent msglength
Faztkarvroom89 is offline
Old 03-16-2012, 01:43 PM   #5
Travis H
Travis H's Avatar
Travis H is an unknown quantity at this point
Ill take the driver side door power options, the dome light and the passenger kick panel, pm me about shipping to canada. Will pay.
Travis H is offline
Old 03-16-2012, 01:45 PM   #6
K!lling4Status
K!lling4Status is an unknown quantity at this point
pm sent...............
K!lling4Status is offline
Old 03-16-2012, 02:32 PM   #7
RB240Coupe
RB240Coupe's Avatar
RB240Coupe is an unknown quantity at this point
pm shipping info on pignose bumper and the third brake light to 24277
RB240Coupe is offline
Old 03-16-2012, 03:05 PM   #8
Vatche
Vatche's Avatar
I think shipping the bumper is gonna be expensive man. U really need it that bad? ill try to get you a quote but im estimating 75-125 for shipping
Vatche is offline
Old 03-16-2012, 03:13 PM   #9
SSCACAHUATES
SSCACAHUATES's Avatar
SSCACAHUATES is an unknown quantity at this point
Hey man PM me i gotta list of stuff im intrested in
SSCACAHUATES is offline
Old 03-16-2012, 03:46 PM   #10
RB240Coupe
RB240Coupe's Avatar
how about the brake light then?
Old 03-16-2012, 04:05 PM   #11
Vatche
Vatche's Avatar
37 shipped on the brake light. Lemme knoe
Vatche is offline
Old 03-16-2012, 04:51 PM   #12
RB240Coupe
RB240Coupe's Avatar
Paypal info?
Old 03-16-2012, 04:54 PM   #13
Vatche
Vatche's Avatar
[email protected] is my paypal
Vatche is offline
Old 03-16-2012, 05:04 PM   #14
RB240Coupe
RB240Coupe's Avatar
alright man should be in ur email.
Old 03-16-2012, 07:19 PM   #15
Dsic240sx
Dsic240sx's Avatar
Dsic240sx is an unknown quantity at this point
any un-cracked dashes laying around? also pretty interested in some of the trunk plastic pieces if you got em.
Dsic240sx is offline
Old 03-16-2012, 09:13 PM   #16
Vatche
Vatche's Avatar
i got the payment for the third brake light thanks, ill ship it tomorrow.
the uncracked dash i had was taken from me at knife point by my friend. haha.
i have all three grey coupe trunk trim plastics for 35. lemme know
actually i have 2-3 almost full hatch interiors and a few coupe interior pieces left
Vatche is offline
Old 03-16-2012, 10:38 PM   #17
s13-ghost
Trader Rating: (18)
s13-ghost is a well-known jackass
Feedback Score: 18 reviews
vatche lmk on the things i need
s13-ghost is offline
Old 03-16-2012, 11:04 PM   #18
kumokun
kumokun's Avatar
kumokun is an unknown quantity at this point
got the rubber shift boot by any chance? text me @ 8082910678
kumokun is offline
Old 03-17-2012, 12:19 AM   #19
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
Vatche wanna trade for that buddy club for my greedy ti-c it has silencer to
S-Nation S13 is offline
Old 03-17-2012, 01:59 AM   #20
xh3nry
xh3nry's Avatar
xh3nry is an unknown quantity at this point
Hey i'm interested in buying your s14 seatbelts, do you know if the s14 rear seat belts would fit an s13? Also interested in buying the coupe pillar trimmings for the passanger side, glove box, and a front yellow sidemarker for an s13. Get back to me please thanks
xh3nry is offline
Old 03-17-2012, 03:41 AM   #21
Vatche
Vatche's Avatar
i have them anytime you wanna meet up. u needed manual door panels right?
we can figure out the amount, i gotta check how many door panel sets i have
i do, and i will text u if i dont hear back here.
I dont really want any aftermarket exhausts, and i definitely cant afford to put out any more cash. I also have a guy who wants it shipped waiting on pics.
I can have all those parts in garden grove monday, or in costa mesa saturday.
s14 seat belts do work in the rear also, I am 90% sure.
which sidemarker do you need passenger or driver?
Vatche is offline
Old 03-17-2012, 05:12 AM   #22
xh3nry
xh3nry's Avatar
Passanger front fender, can you give me a deal on the s13 seat belts and sidemarker?
xh3nry is offline
Old 03-17-2012, 09:28 AM   #23
S-Nation S13
Trader Rating: (92)
Some say I'm crazy but I'll straight trade you
Old 03-17-2012, 10:34 AM   #24
Bushido
Bushido's Avatar
i will take the side marker light in this pic. PM me a price shipped plz.
Bushido is offline
Old 03-17-2012, 10:58 AM   #25
s13-ghost
Trader Rating: (18)
i hit u up on monday
Old 03-17-2012, 11:57 AM   #26
Vatche
Vatche's Avatar
ok ill do 70 picked up in garden grove
im thinking about it..
pmed
okee dokee
Vatche is offline
Old 03-17-2012, 12:43 PM   #27
Nissan206
Nissan206's Avatar
Nissan206 is an unknown quantity at this point
How much for S13 steering wheel undertray trim piece, S13 headliner trim piece, and one passenger door handle shipped to 98058? I see you sold the grey 3rd brake light already ;(. I have paypal ready. PM me with price asap plz.
Nissan206 is offline
Old 03-17-2012, 02:27 PM   #28
isaac5021
isaac5021's Avatar
isaac5021 is an unknown quantity at this point
i want the power window amp when are you in oc
isaac5021 is offline
Old 03-17-2012, 02:29 PM   #29
S-Nation S13
Trader Rating: (92)
coo coo lemme know hehe
Old 03-17-2012, 04:39 PM   #30
chiboy002
chiboy002 is an unknown quantity at this point
headlight covers to 60093??
street dancer.
GLEAM
chiboy002 is offline
brembo, endless, part out, s14 5 lug, welded diff
