02-15-2012, 04:33 PM | #1 |
*Testing Waters* Fully Built blacktop SR20 part out - AEM, HKS, TIAL, GARRETT, ACT :[
MORE PARTS COMING, STAY TUNED..
NOT DESPERATE TO SELL, BUT EVERYTHING MUST GO! MAKE OFFERS!! Long story short. Had a friend of a friend do the machine shop work on my sr20det, sleeved it for me and it was done wrong. So I'm deciding whether or not to rebuild another sr with all my parts or just scrap the entire project. Here is a rough list of what was installed and never ran, some parts are used but all are in perfect working condition. All prices are picked up in San Diego. -- These Cams and Cam gears were purchased brand new then installed into a motor but never ran. Two bolts are missing from one of the cam gears but they can be ordered easily by contacting HKS for cheap no more then $20. Costed close to a grand for these parts brand new so take advantage and get yourself a steal. HKS Step 2 Intake and Exhaust Camshafts - $400 HKS Adjustable Cam Gear - $200 OEM S14 Water Pump Unused - $50 OEM S13 sr20det Water Pump *Came off a running car, worked perfect* - $20 S13 sr20det Unused Timing Chain Kit - $150 S13 sr20det 3 Piece RZ Ralco Blue Anodized Pulley Kit - SOLD S13 sr20det Unused Nismo Low Temp Thermostat - $50 AEM Engine Management System Version 1 - SOLD to meano_lover DiF Fan Controller - SOLD to Karlitos Altima Electric Fans - $40 *Pick Up Only* S13 sr20det Unused Koyo Aluminum Radiator - $200 *Pick Up Only* S13 sr20det Unused Koyo Radiator Cap - SOLD to Karlitos S13 sr20det Adjustable Fuel Pressure Regulator - SOLD No Name Oil Catch Can Polished Silver - $20 Sentra SER SPEC V GOLD Brembo's that are fully loaded with brand new rotors, nearly new pads and lines. This is a bolt on upgrade for S13 and S14. They are over 13 inches in size. In fact the piston size is the same as the 350Z Brembo. 3They use a 296mm diameter rotor (12.1 inch) same diameter as the R32 GTR. The rotors for them stock are 4 lug but you can drill them for 5 lug just like people do when running Z Calipers on a 4 lug car. FULL FRONT BBK - $400 Nissan Sentra Spec V Rear Rotors Brand New in the box - $40 *Pick Up Only* S13 sr20det Blue "Power"? Silicon Radiator Hoses - SOLD to riptor S13 sr20det HKS Twin Power Ignition System - SOLD to speedgod^s13 S13 sr20det Transmission NO GRINDS SHIFTS PERFECTLY - $250 *Pick Up Only* S14 Grey Cloth Front Seats 9/10 Near Perfect Condition with sliders and mounting brackets - SOLD locally Blitz SBC ID Boost Controller - SOLD to CHEN FUK YU Blitz Turbo Timer - SOLD to xSoCalxRiderx125 S13 sr20det Mishimoto Starter ~2k miles - $140 S13 sr20det Stock Alternator *Unknown Mileage* - $50 S13 sr20det Stock Fan Shroud *Crack on one of the fins* - $5 Mishimoto Black Front Mount Intercooler and piping complete with couplers, hardware, hotpipe and Greddy Knockoff BOV - $250 *Pick Up Only* Garrett t3/t4 57 Trim Turbo - SOLD Locally. Tial 38mm Wastegate (F38) with Small Blue Spring & Dump Tube - SOLD S13 240sx Apexi N1 32 Way Adjustable Coilovers ran for ~3k miles - $850 *Pick Up Only* Set of four (4) Sportmax 006 wheels and tires for sale. The two rear wheels are 18" x 9.5" and the fronts are 18" x 8.5". The lug pattern is 4 x 100 AND 4 x 114.3. The rear wheels are wrapped in 275/35/18 Nankang Ultra Sport NS-II tires while the fronts are 245/40/18 with the same tires. Tires have ~3k miles. - $750 *Pick Up Only* Unused Act 6-Puck Heavy Duty Unsprung Clutch Holds 463 ft/lbs of torque - $325 S13 Harness Bar, Easy Install and Mounts very well! - $160 S13 Strut Bars Front and Rear - $60 2x Unused S13 sr20det ISIS downpipe - $80 each S13 sr20det Unused ISIS Cast Top Mount Turbo Manifold - $140 S13 sr20det Freddy Intake Manifold with Stock Throttle Body - $160 S13 sr20det Stock Fuel Rail - $50 S13 sr20det Stock 370cc Injectors - $100 S13 sr20det Oil Dip Stick and Dip Stick Tube Brand New from FRSport - $40 Pics of everything I was able to get to. http://s651.photobucket.com/albums/uu238/ohhfasho/ LET ME KNOW IF YOU NEED ANY STOCK PARTS, HAVE A TON OF STUFF. Can get pictures of whatever you are interested in. -Thanks Jaren D. Last edited by jarend; 03-17-2012 at 10:27 AM.. |
02-15-2012, 05:04 PM | #3 |
02-16-2012, 07:39 AM | #10 |
fyi...
12.1 inches does not equal 296mm the brembo calipers use a 305mm x 22mm rotor |
02-16-2012, 01:05 PM | #12 |
02-17-2012, 06:08 PM | #17 |
Got the pictures of the AEM EMS in the photo album as well now. Let me know if you guys need any other pictures. Trying to get the cams and cam gears by the end of the weekend. Sorry for the lag guys.
Pictures by ohhfasho - Photobucket Pictures by ohhfasho - Photobucket Pictures by ohhfasho - Photobucket |
02-18-2012, 11:34 PM | #25 |
02-19-2012, 01:47 AM | #26 |
Don't mean to be an ahole bro, but you should really come down on price for nismo thermostat. I know frsport sells them for that much but you gotta check this out.... NISMO JDM LOW TEMPERATURE THERMOSTAT and that's the regular price....
02-19-2012, 10:21 AM | #28 | |
Haha, bummer. Lowered to $50!
02-19-2012, 11:09 PM | #29 |
Will get more pics by Tuesday and I don't think they would clear. Definitely will clear these 006's if you want a package deal
