Boost gauge install help
I have a center vent pod for my boost and wideband gauges, but I don't know how to remove the center vents (yes I searched) and the frame that holds them, and don't know where to drill through to run the boost line without screwing something up.
Anyone else with center vent gauges that can share some knowledge? I've been boosted since september but still haven't got to properly installing this..The boost line is currently running out my hood and through my passenger window... |
I have the fins and the middle part of the vents out, but I don't have the actual surrounding frame that goes into the hole out. It is like the inner part that connects to the ac ducting. Still don't know where to drill.
#5 |
u have to remove the vents and trim etc for it to fit properly
u can run the line thru the fire wall where engine harness comes thru do not t from fuel pressure regulator
シチサnw/sr20det:stolen |
#6 |
You have to remove the dash to get that center vent out. Takes about an hour if you haven't done it before. Takes me about 15-20 min since I've pulled it out a couple of times to install gauges
Sent from my iPhone using Tapatalk |
#7 |
I have to remove the entire dash just to take out that little vent? damn, how do you get the boost line from where the harness goes through to the back of the gauge? Doesn't seem like a very direct route at all.
#9 | |
![]() Oh and just run the nylon hose where the ecu wiring comes in. Just tuck it in there and be careful pulling it through. Kinks easy!!
![]() Last edited by freeagent3117; 01-27-2012 at 07:28 PM.. Reason: Forgot Info |
boost, center, gauge, vent, wideband |
