![]() Join Date: Oct 2006
Trader Rating: (163)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 163 reviews
(2) S15 SR 6-Speed Transmissions
I have two S15 6-speed transmissions for sale. One of them is out of my own car. I ran it for 4 years with 400whp without a single issue. It includes the following:
Asking $400 OBO... will ship at buyers expense. The second one I picked up from a friend out of a parts car. It includes the following:
Asking $350 OBO... will ship at buyers expense. I also have an OEM S15 SR 6-speed clutch I would give away with either transmission. On top of that I have an unknown steel driveshaft for this transmission into an S13... most likely a Driveshaft Shop. But since I do not know the brand I will also give it away with one of the transmissions. Or $650 for everything I have listed ![]() |
#6 | |
![]() Join Date: Jun 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
Toby, I know you are trying to keep it with the transmissions...however, whenever/if you change your mind I will still gladly purchase the transmission cross member for the 6spd. |
#10 |
Banned from the Marketplace
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() Feedback Score: 21 reviews
Any idea on mileage? I'm currently looking for a transmission and have went thru 3. Wasn't sure if I would go with this or a z33. This is obviously the cheaper option, I'm just worried about another one going out on me. Do you need the rear end for the 6th gear to work?
#11 | |
Long answer: You need the rear end and a dakota digital box to make your speedo work. But if you're running an ABS Model S13 you should be able to tap into your abs diff housing and get the signal from the abs sensor, Then you'd need a driveshaft (driveshaft shop). You also need the s15 transmission bolts to mate with the SR20. I'm not sure if you need the dual mass flywheel but I'm almost positive you do + the flywheel bolts for an s15 because they're longer for the dual mass flywheel. And you'll need the 6 Speed Trans. cross member. I'm doing the total opposite swap right now (S15 SR Engine to S14 SR Trans) and what I told you is basically the opposite of everything I had to do. |
#13 | |
Correct, for everything I have listed! |
broadfield, s13, s15 sr 6-speed, transmission |
