11-14-2011, 06:07 PM | #1 |
Godspeed Project S13 S14 Steering Angle Adaptor
These are going for: $35 picked up or $40 Shipped (California customers please add 9.25% to shipped price for shipping cost.) Now in stock is the S13 / S14 Steering Angle Adapter. Comes with: (1) Steering Angle Adapter & (1) 7mm spacer (Optional for bit more angle) Below is the specifications when used with the spacer: GODSPEED steering angle adaptor will allow your steering angle from 38 degree (oem) to 52 degree (gsp adaptor). That is a total of 14 degree gain over stock. Simply install the adapter on the passenger side of the steering rack and re-center the rack after install. That's it! (See pictures below for example) OEM vs. Godspeed Project Leading wheel: OEM is 38 degrees vs. Godspeed is 52 degrees Trailing wheel: OEM is 30 degrees vs. Godspeed is 39 degrees Turning circle (curb-to-curb): OEM is 30 feet vs. Godspeed is 24 feet Lock-to-Lock: OEM is 3 turns vs. Godspeed is 2.8 turns Angle after adapter installed:
Godspeed Project 2518 Continental Ave El Monte CA 91733 P: 626-442-3988 W:godspeedproject.com www.facebook.com/godspeedproject Last edited by Fatboy Garage; 10-10-2013 at 12:18 PM.. |
11-15-2011, 11:21 AM | #2 |
how does the lock to lock decrease when lengthening the steering rack? i think you have a typo there..
but this is pretty cool, do you have to remove the bump stops on the control arms?
11-15-2011, 11:35 AM | #3 |
It decreases lock to lock because you basically hit the bump stops faster when you increase the steering angle this way.
If you remove the bump stops i'm sure you would just get that much more steering angle. |
11-15-2011, 01:05 PM | #4 |
still have these in stock!
Godspeed Project 2518 Continental Ave El Monte CA 91733 P: 626-442-3988 W:godspeedproject.com www.facebook.com/godspeedproject |
11-16-2011, 07:49 AM | #5 | |
.. really now... the gear ratio never changes in the steering rack, so if the lock to lock is defined ONLY by the bump stops on the control arms, then it wouldn't matter if you put a 15" spacer on the rack, the rack cant push beyond the bump stops. my main question was do the bumpstops have to be removed, and i think the answer is yes.
11-16-2011, 12:16 PM | #6 | |
No, the steering stops do not HAVE to be removed. Its not necessary, you can grind down them down to get even more of an angle. But these adapters can be installed without having to grind down the steering stops.
11-16-2011, 03:39 PM | #7 | |
11-17-2011, 02:49 PM | #8 |
Still have these in stock.
11-18-2011, 01:11 PM | #9 |
Still available!
11-21-2011, 11:34 AM | #10 |
Still have these in stock!
11-23-2011, 11:48 AM | #11 |
These are still available!
11-24-2011, 04:38 PM | #12 |
Got Mine, Thanks. will get some pics posted Install time was 45min total with alignment and rack re-center.
Check Out My S13 Build |
11-24-2011, 04:53 PM | #13 |
im curious. if you bought one for each side would it make both wheels have 52 degrees of steering angle? why do you only get one? and wouldnt only having one mess up your tire wear when turning?
11-25-2011, 01:12 AM | #14 | |
You only get 1 because you Re-Center the rack after you install it, and you have to get you Toe angle re-aligned.
11-25-2011, 07:28 AM | #15 |
well i have tien inner and outer rods and stock lca. so if i got 2 of these wouldnt it hit the bump stops but give me max angle for both wheels? i just dont really understand how it can be god to have more angle on your leading tire than your trailing tire. seems to me that it would cause alot of wear on the trailing tire as well as mess with your drifting fluidity. so if i got adapters for both sides would it allow me more angle for both sides keeping them the same?
11-25-2011, 01:17 PM | #16 | |
Do some research in the roll center thread. A-lot of your questions will be answered there.
11-25-2011, 01:46 PM | #17 |
i attempted to read and understand the whole suspension thread that was about setting up a car for drifting and couldnt understand any of it.. i tried reading the threads they sent you to to help understand it and it got all mumble together and got confusing to me.. ill try to look it up again..
11-25-2011, 06:51 PM | #18 | |
Just order 1 adaptor, recenter your rack, and enjoy the extra angle. If you need more, you will have to get some Steering Knuckles, and notch or buy some new FLCA (front Lower Control Arms) so your tie rod ends dont hit. I think God Speed has everything you need for suspension.
11-25-2011, 10:39 PM | #19 |
haha.. ok thanks... do you think you could simplify the roll center stuff? i think i understand the concept behind it. its a ratio based between your center of gravity and where you knuckles are? and having your roll center at the same level or a bit higher you get less body roll and more steering angle? am i right about this?
11-28-2011, 07:38 PM | #20 |
50% off sale going on today, last day.
http://zilvia.net/f/advertiser-announcements-feedback/420917-godspeed-project-black-friday-special-50-off-msrp.html
11-29-2011, 11:38 AM | #21 |
Still have these angle spacers in stock!
11-30-2011, 11:46 AM | #22 |
Still have these angle spacers available!
11-30-2011, 11:47 AM | #23 |
Got mine installed.. Thanks guys =)
11-30-2011, 11:59 AM | #24 |
NICE! You are very welcome.
12-01-2011, 10:58 AM | #25 |
Bump still have a few of these left in stock!
12-02-2011, 02:38 PM | #26 |
Still have this in stock!
12-05-2011, 04:48 PM | #27 |
in stock ready to go!
12-05-2011, 06:34 PM | #28 |
Took me from doing 3pt turn arounds to 1 single turn at full lock on a 2 lane street. good mod for the price! Thanks Again.
12-06-2011, 11:02 AM | #29 |
Still in stock!!!
12-09-2011, 11:25 AM | #30 |
Still have these available!
