11-05-2011, 06:53 PM | #1 |
threadlock for turbo bolts? Anything on lines that go to block on SR?
1. Is there any substance I can use on the bolts of my turbo to stop them from comming loose? Will high temp thread lock work?
2. Do I use anything on the threads of the oil and water lines that thread into the alluminum SR block? I'm paranoid about them coming out and blowing my motor, but I also am terrified of stripping them.... Should I use PVC thread tape before screwing them back in? Thanks! |
11-05-2011, 06:58 PM | #2 |
Trader Rating: (81)
Feedback Score: 81 reviews
1. Use some anti-seize lube and these if stock turbo, which it sounds like, use the locking tabs.
2. Nothing's needed. Don't overtighten or you will strip the bolts.
11-06-2011, 03:38 PM | #5 |
Man w/ CTSV & a Car Seat
If you're worried about the turbo bolts coming loose (turbo to manifold or elbow bolts), invest on some DP with a flex pipe on it. Nothing else will keep your bolts on than taking the pressure off them.
11-07-2011, 12:34 AM | #7 |
Trader Rating: (82)
Feedback Score: 82 reviews
Get motor mounts that's your problem on why they are backing out. I had this issue on my car, got new mounts and never had this issue again
NEED Bolt kits for your car? |
