07-20-2011, 12:29 PM | #1 |
Trader Rating: (18)
Feedback Score: 18 reviews
Origin-bride-garrett-rc-ets-kisuu-ross tuffbond-turbosmart-!*!*!*! Tons more !*!*!*!
1. NO BASHING PRICES OR PARTS! if you dont like it, please leave!
2. If you PM, please also bump the thread. 3. Im always adding more parts and pictures to the thread, so check back every so often. 4. More parts have been added or prces dropped as of...7-23-11 PARTS FOR SALE! Bride RHD S14 FRONT Floor mats (Imported from Japan) - NEVER USED - PERFECT SHAPE - $225 Turbosmart Megasonic BOV - Roughly 1k miles - PERFECT SHAPE - $125 Unknown Brand BOV - Slightly Used - PERFECT SHAPE - $50 S15 Hoods - NEVER USED - $225 RC 1000cc Top Feed Injectors - SOLD! - NEVER USED - $300 Kisuu Custom Made Billet Top Feed Fuel Rail - NEVER USED - $150 ETS Custom Made Intercooler 24X8X3 - NEVER USED - PERFECT SHAPE - $175 OEM Redtop Injectors - USED - PERFECT SHAPE - $50 Origin Canards w/ Custom Aluminum Under Shield - NEVER USED - PERFECT SHAPE (shiny parts are just the flash from the camera and some of the mounting holes) - $180 S13 Black top ECU -Perfect SHAPE - $125 Garrett 3071 BB Turbo with 4 bolt turbine housing - SOLD! - ~300 miles - PERFECT SHAPE - $1100 ROSS TUFFBOND Harmonic Balancer (Rated to hold 1500hp and retails for almost $500) - SOLD! -ONLY MOUNTED -PERFECT! - $375 ROSS TUFFBOND Water Pump Pulley -ONLY MOUNTED -PERFECT! - $90 S13 KA24DE ECU (Calum Board Chipped) - SOLD! - PERFECT SHAPE - $90 S14 SR20 88.5mm Cometic Metal Head Gasket multilayer - NEVER USED - PERFECT SHAPE - $70 OEM SR20VE Valvetrain (IN+EX Valves, Springs, Cams, Gears) - 15,000 Miles - PERFECT! - MAKE OFFERS ON WHAT YOU NEED! S14 Non-ABS Driveshaft - Used - $110 S13 Non-ABS Driveshaft - Used - $110 S13 SR Transmision - SALE PENDING - Roughly 30k miles - PERFECT SHAPE - $150 These are all the make an offer items...i dont want or need them all so just make an offer...pictures of these upon request...its to many pictures for the thread. S13 SR OEM Coil Pack Cover BNIB SR Multi Layer Exhaust Gasket BNIB OEM SR Exhaust Gasket SR OEM Exhaust Manifold w/ Heat Shield (1) V1 Godspeed S13 Toe Arm (1) V1 Godspeed S13 Traction Rod Valve Cover Gasket - SOLD! Valve Cover Coil Plug Gasket Water Outlet Water Inlet (4) Cam Oil Tubes (2 Sets) (16) OEM Spring, Retainer, and Keeper (1 set) (8) SR OEM Intake Valves (1 set) (8) SR OEM Exhaust Valves (1 set) (8) SR OEM Rocker Arm (1 Set) (8) SR OEM Lifter (1 Set) SR Block (bare) w/ 87mm bore (needs align bore...roughly 200 at any machine shop) SR20 Front Cover w/ Oil Pump (2) Oil sandwich plate Galley w/ sensor (2) Upper Oil Pan (2) Water Pump Water Pump Pulley (3) Rear Crank Case Cover Crank Pulley - SOLD! (4) SR Oil Squirters (1 Set) (3) SR OEM Rod (4) Upper Oil Pan Screen (2 Sets) (3) Different SR20 Timing Chain Guides (3) SR Timing Chain Tensioner (2) SR Main Cap Girdle (2) Alternator Bracket AAC Valve (3) Knock Sensor (3) Coolant Tubes (2) Thermostat Housing (2) Coolant Temperature Sensor Housing 3” S14 Exhaust that was very hacked up but it has a Very good condition HKS muffler Turbo Blanket (was on a T67) - SOLD! SR Transmission Plate SR OEM Turbo Lines S13 Rear OEM Chamber Arm S13 Rear OEM Traction Arm S13 Rear OEM Toe Arm stock KA24de fuel pump (in working order) stock KA24de header + stock heatsheild stock KA24de airbox intake system and Filter is still clean Summit Liquid Fuel Pressure Gauge SOME PHOTOS, MORE TO COME! FWD SR20DE...EJ20...SR20VE- If you need any parts for one of these motors, let me know…im sure I’ll have them.
https://instagram.com/eck_matthew/ Last edited by Imarvin240; 08-03-2011 at 08:35 PM.. |
08-02-2011, 11:24 PM | #16 |
Trader Rating: (18)
thanks guys!
all shipped out, hah you should probably have it by now with how long it has taken me to reply to this yes, it is its sold, sorry thank you, sir
https://instagram.com/eck_matthew/ |
08-05-2011, 11:19 PM | #19 | |||
Future Moderator
