Old 06-25-2011, 10:55 PM   #1
SilEightyRHD
SilEightyRHD is an unknown quantity at this point
Oil in intercooler piping
Had an exhaust leak and was taking everything off to change a gasket and there was oil caked inside the IC piping all the way down to were the piping meets the IC. I have the manifold and turbo out and the turbo (T25) has a LOT of shaft play...am I better off upgrading or rebuilding
SilEightyRHD is offline   Reply With Quote
Old 06-25-2011, 10:58 PM   #2
StReeTz
StReeTz's Avatar
StReeTz is an unknown quantity at this point
Depending on your budget I would upgrade. S15 turbo is a nice upgrade. I would also invest in a catch can setup.
StReeTz is offline   Reply With Quote
Old 06-25-2011, 11:01 PM   #3
SilEightyRHD
thats a t28 correct...and the stock motor has a catch can does it not
Old 06-25-2011, 11:18 PM   #4
StReeTz
StReeTz's Avatar
Yes it is a T28. The stock motor does have a catch can, wasn't sure if you were running it or not. Most ditch it for an aftermarket setup due to its poor location.
Old 06-25-2011, 11:31 PM   #5
SilEightyRHD
why is it in a poor location
Old 06-25-2011, 11:36 PM   #6
StReeTz
StReeTz's Avatar
Usually it is in the way when trying to swap manifolds. But if you're still on the stock manifold and everything it shouldn't be in the way.
Old 06-25-2011, 11:39 PM   #7
SilEightyRHD
should i upgrade the manifold also...or stay with the stock manifold...i have heard the stock mani holds up better than some of the aftermarket ones out there
Old 06-25-2011, 11:47 PM   #8
jr_ss
You'd be correct, it also retains heat better helping with turbo spool, but... It doesn't flow well unless it's need opened up some with extrude honing. I personally think you'll be fine with a stock manifold if you're just swapping an S15 T28 on...
Old 06-25-2011, 11:55 PM   #9
SilEightyRHD
how much boost can the t28 handle
Old 06-25-2011, 11:58 PM   #10
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
Around 13-15 after that it's kinda pointless.
SLiDe_WaYz is offline   Reply With Quote
Old 06-26-2011, 12:03 AM   #11
SilEightyRHD
13-15 psi...thats exactly what i was thinking
Old 06-27-2011, 12:33 AM   #12
SLiDe_WaYz
SLiDe_WaYz's Avatar
Yea man anything past that its pretty pointless.
intercooler piping fmic, leak, oil, s13, turbo
