05-21-2011, 02:51 PM | #1 |
Trader Rating: (53)
Feedback Score: 53 reviews
// SR20DET Parts Galore - LOOK Inside//
// SR20DET Parts Galore - LOOK Inside// Email > [email protected] < Paypal send payment as a personal gift or pay the 3% fee - add in note what your paying for as well as your shipping address. Concord, NC 28205 Email/PM me offers or to get shipping quotes / I need your City/State/Zip All prices do not include shipping __________________________________________________ ____________________________________________ FS: SR20 JE 87mm / 3.425in .040 over stock (86mm / 3.386in) - 8.5:1 CP Pistons FYI Stock SR20 pistons are - 86mm / 3.386in with a 8.5:1 CP Will work on any SR20 Used but in perfect working condition Rings are in good shape but will need to be file fit to your block a new set can be had for $100 or less - if needed 1 piston has been banged around but nothing affects its performance Another piston has a few scars on the skirt but again will not affect the performance The carbon build up (not bad at all) will clean right off with whatever way you use - if you dont know any ways to remove it google search there are tons of ways to do it - I just have not had time to clean them. These are $600.00+ new $350.00 Download the Piston spec sheet: http://www.jepistons.com/PDFs/TechCorner/S..._instrc4032.pdf In case you cant read the micrometer - in the first pic - it reads 3.4245 - all pistons are in the range of 3.4245 - 3.425 - this is measuring from bottom of skirt up 1/2in in an 80deg. garage __________________________________________________ ____________________________________________ SR20DET Greddy Oil Pan Painted black - can be removed easily 1 long and 1 short bolt is missing - $.50 @ hardware store Each baffle is missing a screw as they dont line up - but they are secure and not going anywhere Used on a rebuild that made it to idle and then the whole project was parted out. I was going to use it on my project SR but need $ of other things $285.00 __________________________________________________ ____________________________________________ SR20DET Redtop Valve Cover Normal wear and tear - nothing major - great for a core on powder coating or use it as-is. No hardware - valve cover only. $75.00 If you want a coil pack cover add $25.00 __________________________________________________ ____________________________________________ FS SR20DET GREDDY / TRUST / GREX METAL HEAD GASKET Brand New in Box I was going to use it on m SR build but need the money for more important things Part # 13521183 88 1.4mm This will work on any bore size 88mm and smaller FYI - Stock SR - Bore & Stroke 86mm x 86mm $265.00 new from Greddy http://www.greddy.com/products/engine/meta...er:make:Nissan/ GReddy $215.00 __________________________________________________ ____________________________________________ SR20DET Front timing cover with oil pump $70.00 __________________________________________________ ____________________________________________ SR20DET Bottom mount turbo manifold - turbo mounting stud will need to be replaced $70.00 __________________________________________________ ____________________________________________ SR20DET Ignitor - came off a redtop harness $55.00 __________________________________________________ ____________________________________________ SR20DET Coil pack harness - came off a redtop $45.00 __________________________________________________ ____________________________________________ SR20DET tranny to motor dust plate $45.00 __________________________________________________ ____________________________________________ SR20DET Flywheel - off a redtop needs resurface $25.00 or $75.00 resurfaced __________________________________________________ ____________________________________________ SR20DET 370cc injectors and fuel rail (no FPR) $100.00 __________________________________________________ ____________________________________________ SR20DET RWD ARP Head Studs 1 torque cycle $90.00 __________________________________________________ ____________________________________________ S13 Redtop SR20DET A/C Bracket $45.00 __________________________________________________ ____________________________________________ S13 SR20DET T25 Turbo Lines $10.00 each or both for $15.00 __________________________________________________ ____________________________________________ S13 SR20DET Alternator Bracket $30.00 __________________________________________________ ____________________________________________ SR20DET Brand New Clutch & Flywheel Bolts $30.00 __________________________________________________ ____________________________________________ S13 SR20DET Throttle Bodies with Auto TPS $25.00 __________________________________________________ ____________________________________________ SR20DET Stock Crank, P/S, Alt. Pullies Crank has small chip on A/C side - Hurts nothing - Only cosmetic $50.00 __________________________________________________ ____________________________________________ S13 SR20DET Intake Manifold (Bare) $30.00 |
06-12-2011, 06:43 PM | #11 |
06-12-2011, 07:57 PM | #13 | |
Trader Rating: (53)
$80.00 shipped - [email protected] send as a gift or pay the 4% fee |
06-12-2011, 08:15 PM | #15 |
Well as it turns out I powder coated it, so if you'd like I can make it any color you want and we can trade even. The letters are red right now, but I can do them in silver. Lmk.
06-12-2011, 08:42 PM | #16 | |
Trader Rating: (53)
I will even trade that - you gonna come to me for the trade or are we shipping? I also have another deal for you - what is your email - I dont trust pms as mods can actually look at them. |
06-12-2011, 08:51 PM | #17 |
It's my screen name @yahoo.com
I could probably just come pick it up. Do you ever go to cars and coffee in mooresville? If you're not in any hurry we could trade there.. |
06-12-2011, 10:09 PM | #19 |
How bout 100 for 2 of them shipped and u can keep the oil pumps out of them is like to have a back up I'm having problems with them cracking under the driver side bolt that goes through head
06-13-2011, 05:03 AM | #20 | |
Trader Rating: (53)
06-20-2011, 07:36 AM | #28 |
460
