04-18-2011, 08:03 PM | #1 |
JDM doorsills, Grill, Cusco RSTB, Do-Luck RXB, etc.
I have a bunch of stuff setting in my garage. Please see pictures below.
1. Apexi power intake and K&N typoon piping for intake. Not a complete setup, needs hoses. $90 plus shipping. 2. JDM lightup doorsills. Two sets. One is off of my car and was working. Other is amature repaired and repainted but probably not light up without new glow strips. Both sets for $230 shipped. See below post for updated info on the Sills. 2a. Silvia Grill in pic is $125.00 plus shipping. 3. CUSCO carbon RSTB. Very good condition. This does not require you to cut anything. $200.00 shipped. 4. S14 Kouki taillights. Make it worth my effort to remove them then I will. USDM OEM lights. Last edited by Zen S14; 04-29-2011 at 05:39 AM.. |
04-18-2011, 10:55 PM | #6 |
^^ what he said.
04-19-2011, 05:26 AM | #8 |
Answered pms. The RSTB I will look at again but based upon the weight of the pipe I believe it is a hollow carbon piece and not a Wrap. Without the end pieces the pipe weights nothing much at all.
04-19-2011, 07:28 PM | #10 |
Yes I slapped that on during one of my ricer moments. I actually have the Nismo power brace, radiator cap, fuel filler cover cap on this car but ... nvm. :ghey:
04-20-2011, 07:03 PM | #14 |
Yes I am. Pm me about it. Also, the Louvers are sold. Thank you all for the interest.
I just looked closely at my sills again. Even the good set had a gouge in it and a ding. I think my original price is too high given the conditions. I am dropping the price on them under the assumption you will need to do some refurbishing for the surface. I will take closeup pictures soon and post them up. The good set with scratches and one noticable gouge for $150 shipped and the refurbished (meaning repainted with silver paint) set for $80 shipped. I know the set that came off of the car lights up and the other set I have no idea because it was never installed but I know at least one side has no wire from the indiglo panel. You can see the gouge in the 3rd pic and the ding in the second to last. Also notice there are scratches on the raised portion. These pictures are all of the working set. Last edited by Zen S14; 04-20-2011 at 08:33 PM.. |
04-27-2011, 01:24 PM | #15 |
This is the set I repainted.
1. pic showing damaged area from before and closer look at the paint. 2. back side showing the clips and wiring situation Also this is the backside of the set I had on the car. 3. |
04-29-2011, 05:45 AM | #16 |
OEM plastic headlights I found on the shelf. These are in good condition, no cracks with all tabs in place. $125 shipped for both. I do not wish to break them up individually.
05-13-2011, 10:05 PM | #21 |
Bump. Strut tower braces, door sills, Garage defend carbon cooling panel, new uninstalled S14 Carbon inner doorpanel(made by Origion I believe), stock headlights, two silvia grills, S14 Kouki taillight are all available.
05-13-2011, 11:01 PM | #22 | |
Trader Rating: (38)
Feedback Score: 38 reviews
and it does wonders for the car. i just got one for an amazing price, and i love it. really great item. easy to install once u figure it out. definately makes drifting much easier. im sitting on completely stock suspension (unless u include poly f sway bar bushing lol) with gr2 struts and stock springs, and i have SIGNIFICANTLY less body roll/chassis flex. and theres much less kick back when ending a drift. highly recommend it. glws op
2016 Nissan 370z |
05-14-2011, 04:15 PM | #25 |
Thanks for the Clarification on the Cusco RSTB One_Love_Silvia. The Cusco piece is a great design in that it does not require any cutting and the actual bar sets in the tunnel between trunk and rear seat when installed. The bar itself is superlight. The only real weight are the end plates.
I have received a few requests about the Apexi power filter. I will put it together with the adaptor and heatshield as one piece. $75 for the whole thing plus shipping cost. It should not be much to ship as the weight is not high. The filter I took off and checked for damage and it is in 9/10 condition. Do-Luck bar is being test fitted for my new car. If it does not fit I will put pics up as well as pricing. Origin Labs Carbon Door Panels are Sold! The Garage Defend Carbon cooling panel is for the Zenki. |
05-15-2011, 06:27 AM | #29 |
Unless stated otherwise everything is for the 1995 S14. Everything is from my one car which is being parted out so the following items are being added.
This is a full part out so anything you can think of is available so far as OEM stuff. Most of the below stuff are still on the car so it will require time to remove and ship. Notable items besides what was originally on this thread: Interior is GREEN! before you start asking for trim pieces take note of that. Exterior is a custom adjusted Teal color with more blue. All panels are straight and good. Car was not in an accident. Needs timing chain redo and wiring issue figured out. (car is running but timing is retarded and idle is funky and there are probably vacuum leaks somewhere) I am tired of dumping money into it since I am not mechanically inclined and I don't have any luck with it. If you feel you want to buy this car pm me before stuff start to disappear from it. 95 Zenki. I am willing to rid of this whole car for 6k or I will try to get it out of parts. 1. Nismo Power Brace 2. Apexi World Sport Coilovers 3. Sustech Sway full set front and rear 4. AEM Top feed Fuel rail (purchased February 2011) 5. 550 cc RC injectors (purchased Feb 2011) 6. New installed Turbosmart adjustable fuel pressure regulator (Feb 2011) 7. New installed 255lp Walbro fuel pump (Feb 2011) 8. Tanabe Rear underbrace 9. Apexi carbon FSTB 10. S15 Steering wheel (black) 11. JIC Magic Full Titanium Exhaust (yes full titianium 8lbs from Cat back I can install it with one hand holding it up) 12. 4.636 in VSLD diff OEM S14 diff with Nissan motorsports ring and pinion set 13. 4.343 ring and pinion Diff from Skyline GTS-T VLSD 5 bolt output shafts but with bearings that are likely bad though. 14. Full turbo kit with front mount intercooler (uses on-center T04 turbo, revhard manifold, front mount intercooler (piping does not need battery relocation) and clears brake master cylinder on my auto car) 15. 300Zx Maf 16. Enthalpy ECU tuned for the 550 cc injector, turbo, etc. It is for an auto though. 17. Unorthodox Racing underdrive pulley set minus water pump pully which did not fit right. 18. Built bottom end of motor with AMS advanced rebuild kit. Forged pistons, etc. 19. Two S13 exhaust cams in the motor which can be parted out. (If you want the motor and head with the built setup that is fine but you need to redo the lower timing chain while motor is out. The chain is currently off by some amount I am not sure of. The car runs but timing is retarted and idles funky) I am happy to part out the motor too. 20. Oil pump 6 month old 21. Water Pump 6 month old 22. Tapped oil pan with return line plug welded in 23. OEM 5 lug hubs for non-abs car 24. Q45 Brake setup for front (Nissan Motorsports big brake kit) 25. Door seals and trunk seal are basically new 26. White faced Gauge cluster showing 190k miles 27. Dash with full carbon fiber kit 28. I also have the rear view mirror cover in carbon fiber as well as the center consol lid cover in carbon fiber. 29. Automatic transmission aluminum driveshaft from DSS. 30. German Glass headlights with HID kit. The adjustment shafts in the lights broke (car rides too stiff). The internal lenses will vibrate over rough roads. 40. JUN sideskirts and Rear mudguards. These are authentic JUN pieces not copies. 41. NAVAN Front bumper with a crack near the wheel well on passenger side and one crack on the bottom lip.(both repairable) Turn signals and side marker lights included. 42. OEM 350z rims with snow tires. 43. Ebay tensioner rods with metal ends. |
