![]() I just installed a brand new wiring harness from Wiring Specialties and now the car is getting no power. 1st turn of the key it tried to turn over. Then 2nd 3rd and 4th it just clicked. Then after that it did nothing, and now nothing is getting power. I checked to make sure my alt/starter wires weren't swapped(they weren't) and that everything was grounded which they were. So im really confused on what would cause the car the gradually not get power. I figured if it were a fuse or relay it would've just stopped the first time, not gradually lose power. The battery is also new. So im super stumped
![]() Anyone have any ideas of what it could be or what I should check? S14, sr, new upper harness, ka lower(trans sensors not plugged in) Any input would help since I have no idea where to go now...thanks |
![]() Join Date: Dec 2006
more grounds
1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
#7 |
UPDATE:
Battery is good Grounds are NOW good All fuses are good EGI relay is good *CAR CRANKS BUT WONT TURN OVER* *FUEL PUMP WORKS BUT ITS NOT GETTING POWER* ANY SUGGESTIONS??? |
#8 |
![]() Join Date: May 2008
![]() Feedback Score: 10 reviews
when you say fuel pump works, do you mean youre getting fuel pressure? My car recently did this, and it was insuffecient grounds and it was shorting out the CAS.
#9 |
![]() Join Date: Apr 2008
Trader Rating: (44)
![]() Feedback Score: 44 reviews
yeah check your grounds..i dont know if you have a 13 or 14..but yeah this happened to my s14 a couple of months ago, check the ground on the trunk latch and check the ground on the passenger side front strut tower
#11 |
No fuel pressure but ive checked to make sure the pump works by connecting direct power to it.
Its an s14. All my grounds are good BUT i havent seen this one on the truck latch you speak of. Ill do that tomorrow for sure. Thanks for giving me another thing to look at |
#13 |
Still nothing ;-(
My guess now is it might be the ecu. Saw a guy selling a #62 ecu but the catch was it wasnt turning the fuel pump on. Would check but i dont know anyone with a #62 ecu to let me plug in. How would one check to see if thats the problem w/o a donor ecu? |
#14 |
![]() Join Date: Jul 2005
![]() ![]() Feedback Score: 3 reviews
I had the same problem. There is a wire you still need to tap to turn the ecu on. I think it is an orange wire (34 - Start signal (from ignition switch) - Orange). let me know if it fires up.
#15 |
Okay so i looked into the #34 wire but after reading that its components are nothing with fuel it doesnt seem like thats my problem. MY CAR IS CRANKING BUT NOT TURNING ON DUE TO NOT GETTING FUEL. I actually saw his post on another guys ECU for sale thread talking about it which make me pretty sure/sad that its most likely an ECU problem...
In this video he seems to be having the same problem i am Video Blog 4-1-2009 on Vimeo So now im pretty sure its the ECU, is there anything else that i could check? Am i wrong, does that #34 wire do more than im thinking it does? *Car cranks but wont start* *Fuel pump is good BUT does not prime when not hard wired(so getting no fuel)* |
#16 |
![]() Join Date: Sep 2004
the next video up in the playlist shows me taking the ecu apart and making sure that pathway to the fuel pump is not broken on the board.
You can take a multimeter and check the pin for the fuel pump and the path it starts at. If you're getting acc power, if you're turning the key and cranking it and it turns over but isn't starting and your fuel pump doesn't prime when you turn the key to on. Your ecu is burnt and will need to be replaced of if you're feeling brave since it's already fucked up you can try fixing it like I did. I still have that ecu I repaired but from what I'm reading you have an s14sr? or an s14 with an s13sr? If you want I can mail you out my spare ecu just give me like 10 bucks for postage. It's better than nothing. |
#18 |
Om1kron was kind enough to lend me his spare ecu and sadly im having the same program blem :'(...so I've decided to take my interior apart and make sute no wires are tampered with(doesn't look like they are though)
#19 |
![]() Join Date: Jan 2011
My car is now up and running , had similar issue as you it was my first swap so I was skeptical about everything that I did like my wire harness I've never solder anything in my life so I wasn't sure wtf it was, I've learned how to check pins and all that good stuff.
Anyways mine ended up being a bad ECU japslapsilvia came over to help me troubleshoot with two of his buddies , very nice guy and really intelligent. We did not get the car running that day but we eliminated a lot of things and narrowed down the issue. the symptom was like yours my fuel pump only prime when I grounded the wire, my ECU power wire black/white was not getting any reading at the chassis so that kind of threw us off a little, the fuse was good and relays had power at the connector but nothing going out to my black/white. We tried his harness just to make sure it wasn't harness we didn't try the ECU because he didn't bring it with him. that same day I went a head and bought the ECU off of someone on here because I was very skeptical about mine they sent me a messed up turbo and broken ignitor chip anyways , while waiting for the ECU I started troubleshooting by jumping the relay connectors and everything , I got the fuel pump to prime by jump the relays and I got the the black/white wiring to get power on the chassis by jumping relays, by reading and messing around with the relays I learned a few things, I was about 70% confident that mine would be resolved once i plug in the new ECU and it did, the ECU will control trigger your relays and pretty much get everything synchronized. but since you already got another ECU then IDK, but I do know that the original ECU that i had didn't have any burnt trace it was just fucked up. at one point I had battery very low where the starter would just click , this battery was brand new I took it to autozone and i was surprised when they said it only had 11% left anyway, that's about it. Good luck |
#21 |
Yes sir, its a brand new relay that came with the harness. I'm interested in what Thurman548 was talking about but im not exactly sure what he means by "tap" the wire. Anyone have experience with that?
#22 |
![]() Join Date: Mar 2011
have you back probed the wire(s) from the ecu that either ground the corcuit or power that circuit?
1991 Nissan B13 Sentra sr20det 300whp/1991 Nissan S13 240sx sr20det ~260whp |
#23 |
Cars running now....of course it ended up being the dumbest thing in the world. My F4 plug in the interior had a excess piece of plastic on it that wasnt allowing it to connect properly. Got that plugged in right and the ecu, fuel pump, and the car all turned on. Makes me feel good to know i had everything right, but sad that i had to pay an extra buck and waist so much time.
Om1kron i just realized i still have your spare ecu so ill get that shipped out to you at the beginning of the week. Thanks again |
harness, power, sr20det, wiring |
