Old 03-07-2011, 11:50 PM   #1
curtains
curtains is an unknown quantity at this point
HELP! Brakes still weak after bleeding (lots of times)
OK so I bought a 180sx a while ago that needed alot of work for cheap as chip, now the cars running and drivable and time to get the brakes to go.
I bleed them a few times (like 4 times) now and the fluid would have gone through the whole system a few times, and theres absolutely no bubbles coming out when I bleed them, I never let the master cylinder drop below minimum.
The brakes still seem to be soft and I can press them quiet far down (which is other cars you can usually just press them half down)
if i pump them a few few times then they have pressure (but i don't want to have to drive around and pump them 3 times every time i want to stop).
How do I know if my master cylinder or any other part of the brake system is broken or not, or what else may i have been doing wrong?
oh and another thing my master cylinder thing seems to make this minor noise when i pump it, kinda like a eeeeeee (but real quietly and slowly) donno if thats normal.
curtains is offline   Reply With Quote
Old 03-08-2011, 08:17 AM   #2
Sileighty_85
Sileighty_85's Avatar
make sure brakes bleeder Valve is facing up. If not, they are on backwards.
Its a very simple system, if your 100% sure there is no air in the system then your Brake Master Cylinder is the culprit.
If you get a new one make sure you bench bleed the Master Cylinder.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 03-08-2011, 08:13 PM   #3
Drifting-pedobear
Drifting-pedobear's Avatar
Drifting-pedobear is an unknown quantity at this point
yup. they are upside down, gaurenteed.
i did that myself.
its one of thoes hurp durp moments.
RIGHTWHEELDRIVE.com
Drifting-pedobear is offline   Reply With Quote
180sx, 200sx, bleeding procedures, brakes, s13
