Old 01-18-2011, 01:50 AM   #1
mkezzo16
mkezzo16's Avatar
mkezzo16 is an unknown quantity at this point
Brake Setup Helllp!!!
Bought a pair of JDM Project MU drilled & slotted front Rotors
was told by Mackin industries Rep they are for a 180sx
-researched into what calipers i can use..was thinking 180sx calipers & maxima pads
Issue is Rotor is wayy too big for 180/maxima caliper which is 22mm..the rotor is 28mm thick & the diameter looks about 280mm. WHAT CALIPERS CAN I USE for this..
the width of the rotor is right n between a NA z32 (26mm) and a TT Z32 (30mm)
Please Help so i can get what i need
mkezzo16 is offline   Reply With Quote
Old 01-18-2011, 01:52 AM   #2
mkezzo16
mkezzo16's Avatar
Oh and Btw, I know alot of you are going to say go w/ z32 setup, but car & rotor are 4 lug, keep that in mind
Old 01-18-2011, 01:54 AM   #3
sidewaysil80
sidewaysil80's Avatar
sidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to all
i would imagine you can get away with the ttz32. i mean, brake pads are meant to open and close as the pads get smaller, so if they start off a little closer then normal (if you were using the ttz32 rotor) i don't see that being an issue. just make sure they are fitted and bleed properly.
it shouldn't matter. the calipers are bolting to the spindles, so iirc they don't have anything to do with 4/5 lug. wait i'm positive they don't i've seen 4 luggers rocking z32 brakes.
sidewaysil80 is offline   Reply With Quote
Old 01-18-2011, 02:49 AM   #4
mkezzo16
mkezzo16's Avatar
Gotchaa but i meant as far as doing the complete z32 setup w/ calipers/rotors..on threads where people asked about 180sx setup..most people just say go z32..neway thx for the input
Old 01-18-2011, 05:00 AM   #5
badicalradical
badicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of light
U have the Project MU PN#'s?
badicalradical is offline   Reply With Quote
Old 01-18-2011, 10:23 AM   #6
mkezzo16
mkezzo16's Avatar
I dont Im at work right now..you can check them out here SCR Pure Plus SD624
-they also have only the rears for s13 @ enjuku but..im startin to think maybe i recvd the wrong ones..none of the nissan applications for that rotor state 28mm thickness on their website..
Old 01-18-2011, 11:34 AM   #7
murda-c
murda-c's Avatar
Q45 brakes are 280x28mm
Old 01-18-2011, 12:56 PM   #8
mkezzo16
mkezzo16's Avatar
i didnt even think to check q45 dimensions..thanx .
Old 01-18-2011, 01:09 PM   #9
WISH ONE
My silvia brakes were some odd sizes also.
Old 01-19-2011, 02:24 PM   #10
mkezzo16
mkezzo16's Avatar
im gonna try some q45 calipers..hopefully i can get my hands on some this week
Old 01-25-2011, 05:39 PM   #11
mkezzo16
mkezzo16's Avatar
q45 calipers worked..but just realized 4 lug bolt pattern is off on rotors ..they need to be redrilled
180sx, brake, caliper
