12-21-2010, 11:36 PM | #4 |
go to a hardware store and ask them to figure out the thread pitch for the AN fittings. Theyll either have a key set that you use, or a small placard on the wall with a bunch of threads you can fit and see which it is
street dancer. GLEAM |
12-21-2010, 11:58 PM | #5 |
Just wondering, but how much would you want for the RB20 SMIC with pipes and the RB20 Coil Pack Cover, shipped to 61068? Thanks
........ no |
12-22-2010, 07:33 AM | #8 |
Trader Rating: (47)
Feedback Score: 47 reviews
The cx racing ic pipes would come out to $27.00 paypal, and shipped via UPS ground.
No they do not, maybe for alittle extra I will cut the pigtails off for you? |
12-22-2010, 01:28 PM | #10 |
spacers 10 shipped? pm me if so
http://zilvia.net/f/chat/331550-slyd...pic-heavy.html |
12-22-2010, 02:11 PM | #11 |
Trader Rating: (47)
Considering what I payed for it, I could do 280.00SHIPPED. If soon. I payed alittle over 400 for it. =(
I could do 16shipped to your door. Ups is kinda expensive. |
12-23-2010, 03:12 PM | #15 |
Trader Rating: (47)
Very Large For sale Repost Updated
Very large for sale thread. Most this stuff is just laying around my house, tired of it being in my way all the time. THERE FOR everything is OBO!
S13 240sx fuel pump $10.00 Silver fitting (if there is away to tell size, pm me) $7.00 ka24de valve cover gasket $4.00 sr20det bottom mount turbo coolent feed line (fitting on the end of line is striped) $20.00 s13 240sx 89-93 Tein lowering springs, with badass shocks agy or somthing like that. $SOLD 5 lug 10mm spacers $12.00 ka24de clutch with good life, comes with 2x clutch disks. $20.00 Sr20det, was told it was a nismo. Good life on it. Unsprung. $55.00 g70 maf, s14, works, pulled to do a rb25 swap. $35.00 Rb20det left side only, valve cover. $15.00 JDM clitmate control box, comes with harness $45.00 USDM front s13 side markers, really good condition. $SOLD Left Chuki front bumper extention, used, and primered. $SOLD S13 fuse panels. I got 2x of them. 1x s14 $7.00 S13 left side mirror, looks to be a power mirror. $15.00 S13 tumbler. Works. $20.00 t3 to t3 adapter flange for a 38mm wastegate. $20.00 Left over ic pipes. Sale as a package only $SOLD S14 ecu. 1998, 5 speed $45.00 ka24de termal intake gasket. Never been used. $SOLD s13 front brakes, with brakets. $20.00 2x ka24de coils. Selling them as a package. $20.00 AN fittings for my aeromotive FPR. They fit into a aeromotive FPR. Used to go from an to soft line. $10.00 EACH Rb25det coil pack harness series 2? $25.00 APEXI AVCR Used, and in GREAT SHAPE! Works perfect. $SOLD ka24de starter, works. $15.00 OEM sr20det intake tube. $10.00 /20shipped s13.4 overfenders convertion fenders, need work. Good for a body guy to fix? $60.00 ka ecu. $SOLD Rb20/maxima n60 maf. No pigtail. $35.00 sr20det manifold. No leaks. $20.00 Rb25det/rb20det smic set up. used on my rb25det. I think you will have to cut one pipe. Comes with smic, and pipes. $40.00 Painted, blue blackish ka24de valve cover. Had a local body shop paint it. $40.00 Sr20det redtop valve cover/ka24 valve cover $sr30.00 $SOLD BADASS FUEL SET UP! Used on my rb25det! $300.00 SB FEED LINE, with in line filter & SB RETURN LINE This setup used a aeromotive FPR (not included) Good for A LOT OF HP! 2x walbro fuel pumps, already wired, and TIG welded alu. braket.Of course has the an fittings for the fuel lines. s13 240sx radio brakets $SOLD Rb20det coil pack cover $15.00 ES steering rack bushings. Tension rod bushings, front sway bar bushings $20.00 each UPDATED dec 23! 240sx Right tail light -works, comes with pigtails, and sockets! -$20.00 240sx Left tail light -Works, comes with pigtails, and sockets! -$20.00 Drive 240sx handle -Cliped =( No key. White. -$10.00 SHIPPED 240sx s13 Trim -black, comes with screws. -$15.00 Left over IC pipes -cxracing, pipes with some couplers, 2.5 in. -$20.00 S13 240sx hood latch -works -$10.00 Last edited by Couped_up'd; 12-23-2010 at 08:58 PM.. |
12-23-2010, 03:16 PM | #17 |
Trader Rating: (47)
Passenger (right side) Bride TTM-L Side Mount seat rail. I sold the seat, so no longer need this.
SOLD Pictures. Last edited by Couped_up'd; 12-26-2010 at 06:59 PM.. |
12-23-2010, 03:17 PM | #18 |
Trader Rating: (47)
Ok, so I started to chop up this 240..that is a bitch.
Anyways I found more parts I thought poeple might want. It would be good to see it go to use. Rear Trunk seal 1992 240sx fastback only. -Looks to be in good condition. Did not leak when it was on the car. -$20.00/UPDATE 15.00! Left side Seat Belts -Comes with bolts, brakets, and lower seat belt as well. Whole thing. -Unknown if they work, pretty sure they do. -$25.00 Left side rubber seal -Did not leak, they have all the little plastic peices on the ends. =) -$15.00 UPDATE $10.00 Left side inner rubber trim -Umm..its black? Still good. -$10.00 Left side outside trim -Comes with screws, and lower bracket as well. No dents -$30.00 UPDATE $20.00! Right side seat belts -Comes with bolts, brakets, and lower seat belt as well. Whole thing. -Unknown if they work, pretty sure they do. -$25.00 Right side rubber seal -Did not leak, they have all the little plastic peices on the ends. =) -$15.00 UPDATE 10.00! Right side inner rubber trim -Umm..its black? Still good. -$10.00 Right side outside trim -Comes with screws, and lower bracket as well. No dents -$30.00 UPdate $20! Right and left door switches -Comes with pigtails!, Both work. They also come with the screws -$15.00 1992 240sx s13 gas lid -Primer black, used to be white. No dents. -$10.00 Sportmax center caps -Only 3. Don't know where the other ran off to. Brand new. -$SOLD 1992 240sx s13 door handle -Driver side, kinda rare. Not broken! No key of course. You can use yours. -$20.00 UPDATE $10.00! Ka24de ecu -Works, 91 ka24de, manaul. -$20.00 Ka24de ecu -works, 91 ka24de, automatic. Good for taking out speed limiter on 5 speed cars! -$20.00 Whole trim around steering column -Holds switches, comes with clip, and bolt. -$10.00 right side switch -Comes with the 2 screws. Needed to install. -$10.00 Left side switch -Comes with the 2 screws. Needed to install. $10.00 Tumbler -Unbroken, un cut. -$10.00 2x little trim peices -one is the tilt? the other is the key whole, black. -$5.00 Complete a/c with lines! -No pump...everything else is there. -$40.00 |
