07-28-2010, 04:13 PM | #1 |
SR20DET Eagle Rods & CP Pistons
Hi.
I have for sale a set of Egale Rods, and CP pistons, for the SR20DET engine. Items are used, but in top shape, and prices are a bargain. I am including shipping in the price. Set of Eagle rods (matching set S7). This set was removed from a perfectly good runing engine, due to upgrade plans. These rods have done about 6000 miles. The rods were used only once, on the above engine, and all bolts were torqued using the strech method, using ARP instruments. Rods have been cleaned and inspected. Comes in the original box. Asking price : 250$ Set of CP PISTONS - 86.5mm, 8.5:1 CR, with Bronze Ceramic coating (extra 100$ at CP) on the crown, originaly done by CP. These are the pistons from a sleeved block engine, wich has only been run in, for about 100 miles, before the sleeves leaked coolant into the crank case, and the project was scrapped. Pistons are in TOP shape, exept from some small scratches here and there from normal use, obviously. They come complete, in the original box with everything, but i would recomand using a fresh set of rings. Asking price: 400$ Take both as a package, for 600$ shiped to you !!! If you take both the Rods and Pistons, i can also throw in, for an extra 50$, the folowing set of ARP head studs : ARP MAIN STUDS. These were never used in a runing engine ! They were used during an engine build up, but the block needed to be line honed using these, and as this was not an option at the time, the OEM bolts were used instead. Comes complete, in the original box - exept for the ARP moly lube. Thanks, Dany. |
07-29-2010, 05:26 AM | #3 |
No, sorry.
400$ for those pistons, considering they are coated, and shiped, is low enough. I will allso only sell them for this price, if somone takes the rods as well, at 200$ minimum. Thanks. |
