Old 07-06-2010, 08:23 PM   #1
rollinrps13
rollinrps13 is an unknown quantity at this point
s13 brake light problems s13
my brake lights just stopped working out of no where on my fastback..the fuse is good. just put a new switch in, and its still not working. i put a new stopper thing in the pedal arm to. anyone have any idea what the problem might be???
rollinrps13 is offline   Reply With Quote
Old 07-06-2010, 09:46 PM   #2
rollinrps13
anyone have an idea?? anyone??
Old 07-06-2010, 09:52 PM   #3
michael_torres
michael_torres is an unknown quantity at this point
search it or go to http://zilvia.net/f/chat/297481-smal...w-threads.html
michael_torres is offline   Reply With Quote
Old 07-06-2010, 09:53 PM   #4
rokmplutonium
rokmplutonium's Avatar
rokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the rough
Did you check the bulbs?
rokmplutonium is offline   Reply With Quote
Old 07-06-2010, 09:56 PM   #5
energ
energ is an unknown quantity at this point
Send a message via AIM to energ
are the brake lights the only thing not working ?
energ is offline   Reply With Quote
Old 07-06-2010, 10:56 PM   #6
demonspeed
demonspeed's Avatar
demonspeed is an unknown quantity at this point
if your brake lights AND dash arent working, then you are blowing fuses in the fuse box near your left foot. either That or the magical white box thats in there is bad...i was in the same situation...found out that the Previous Owner installed a CB Radio and left wires bare and thats what caused mine...
demonspeed is offline   Reply With Quote
Old 07-07-2010, 12:16 AM   #7
rollinrps13
yea new bulbs new everything lol..the tail lights work, all the fuses are good, all of a sudden today the brake lights just stopped working. i dont kno about the dash working i just finished a sr swap the interior is still stripped down..is that white box inside the fuse block?
Old 07-23-2010, 01:45 AM   #8
Sako
Trader Rating: (30)
Sako is an unknown quantity at this point
Feedback Score: 30 reviews
Try cleaning the grounds on the housing where you put in the brake light bulbs. It's usually a philips head screw that holds the grounds together and corrosion builds up between them. Get a razor blade and clean the ground contact so that it's shiny and put the screw back in. This happened to almost every single S13 that I have owned.
Sako is offline   Reply With Quote
Old 07-23-2010, 01:47 AM   #9
sidedrifts13
sidedrifts13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
definately the grounds usually they come loose from vibrations, put a bigger screw and clean the grounds with sand paper lika sako said
sidedrifts13 is offline   Reply With Quote
Old 07-30-2010, 01:26 AM   #10
LB 180SX
LB 180SX's Avatar
Trader Rating: (18)
LB 180SX is an unknown quantity at this point
Feedback Score: 18 reviews
i agree, mine had that problem and the ground came loose .. took me a while to figure it out.
definatley check that!!
LB 180SX is offline   Reply With Quote
Old 07-30-2010, 10:00 PM   #11
s13bert
s13bert's Avatar
s13bert is an unknown quantity at this point
Send a message via AIM to s13bert
i was having the same problem, no dash lights, or tail lights, i found some bare wires hanging coverd them up replaced the fuse(blew up about five) and everything is working fine again...
s13bert is offline   Reply With Quote
brake, light, not working
