07-06-2010, 01:21 PM | #1 |
My SR20DET Problem
so cylinder two is misfiring and i dont know why, so far i have checked compressiion, 150, and i swapped coil packs and i swapped spark plugs and also fuel injectors but it still doesnt fire cylinder two, i need more suggestions on what to do
Thanks Jordan 801-891-8188 |
07-06-2010, 01:30 PM | #2 |
Start engine with coil pack off the head and used spark plug in boot, make sure plug is grounded to valve cover.
This way you can see if it's sparking or not. If it sparks, then more like fuel problem.... Is it missing only at idle? |
07-06-2010, 05:30 PM | #7 | |
If it's missing all the time then, it's not vacuum leak. You can also remove valve cover to check #2 locker arms to see it's there. |
07-06-2010, 06:36 PM | #10 | |
Swap coilpacks between cylinders, if the misfire moves cylinders, there's your culprit. Otherwise, its wiring or ignitor. |
misfire, sr20 |
