Old 05-25-2010, 11:52 AM   #1
rsibley22
rsibley22 is an unknown quantity at this point
CA FS. S13 sr fanshroud, s13 VSS, Nismo thermostat,and more!
Well I'm cleaning out the garage to pay for some lame parking tickets.
Anyways, prices are pretty firm and i will ship everything (at buyers expense) if needed to the extents of the U.S. except the FMIC and the Fan shroud.
1.s13 sr20 oem fan shroud - 40
2.s13 manual VSS (vehicle speed sensor) - 50
3.Nismo low temp thermostat 62C - SOLD!!!!
4.Nismo extended wheel studs 50mm(10pcs) for s13 hubs and s14 rear hubs (will not work for s14 front hubs!) BNIB! - 50
5.s14 power mirror switch - 15
6.s13 sr20 fan clutch - 20
7.s14 seat belt buckle (driver side) - 5
8.t25 wastegate actuator 7psi - 10
9.s14 t28 wastegate acuator 6psi - 10
10.s13 sr20 timing chain tensioner (70k-80k on it,works great!) - 10
11.one beat up FMIC 24' x 11.75' x 2.5' still holds pressure it says JDMsport? (came on my car) - 30
rsibley22 is offline   Reply With Quote
Old 05-25-2010, 12:09 PM   #2
hayaimoto
hayaimoto's Avatar
hayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud ofhayaimoto has much to be proud of
Hi I'll take the SR20DET Fan Shroud, Please check PM. Thanks
hayaimoto is offline   Reply With Quote
Old 05-26-2010, 04:38 PM   #3
rsibley22
bump bump, bump it up
Old 05-27-2010, 11:45 AM   #4
Motoskin
Motoskin is an unknown quantity at this point
still got the shroud?
Motoskin is offline   Reply With Quote
Old 05-27-2010, 01:43 PM   #5
rsibley22
the fan shroud is pretty much sold
nismo wheel studs, power mirror switch, s13 vss, thermostat
