![]() NEWEST PICTURES*****
http://www.flickr.com/photos/3082616...7624175139039/ ****** ![]() ![]() All the information and more can be found here: www.greatwhite180sx.blogspot.com Excerpt from blog: Specs Engine: Rebuilt Blacktop s13 sr20det 86.5mm bore Line bored for ARP main stud kit Shaved, Balanced, and Polished Crankshaft Rotating assembly balanced Engine Blueprinted -ARP main hardware -ARP rod hardware - OE Nissan main bearings - OE Nissan rod bearings - CP forged pistons 8.5:1 86.5 overbore - Apexi 1.6mm headgasket - Ported/polished head - Angled valve job - Bronze valve guides - BC valve springs - BC titanium retainers - Greddy rocker arm stoppers - HKS step 1 264 cams - Greddy intake manifold - Nismo/Tomei 740cc injectors - Aluminum high capacity baffled oil pan - Oil pump - water pump Turbo and other components: -AMS Precision gt3251e t3 flanged .63 exhaust housing -Tial 38mm external wastegate -BLU808 custom top mount manifold (currently in R&D) -Custom turbo bracing -Custom V band flange downpipe w/ flex pipe -HKS intercooler with custom intercooler piping -HKS ssqv bov -Koyo Radiator -Samco radiator hoses -Dual flex-a-lite fans -Power FC d-jetro engine control management -Greddy oil catch can -Oil cooler (coming soon) -SARD Fuel pressure regulator Drivetrain: -Nismo engine mounts -Nismo transmission mount -Twin plate exedy clutch -Nismo hardened clutch actuator pivot -Welded differential -Short shifter Suspension: -Tein super drift 10k/8k -Modified steering knuckles -SPL parts tension rods -SPL parts outter tie rod -300zx inner tie rod + steering angle spacers -Crossroads rear sway bar -SPL parts rear toe rods -SPL parts rear traction rods -Powered by max RUCA's -Nismo subframe bushings -Powered by max aluminum subframe inserts Wheels and Brakes: -Work cr kai 17x9 + 17 polished w/ 15mm spacer 215/40/17 dunlop star spec z1 -Work cr kai 18x9.5 +12 polished w/ 3mm spacer 255/35/18 -Grenade wheels 17x9 +15 Gold 245/40/17 -300zx front brakes -axis ultimate brake pads front and rear -stainless steel braided brake lines -spin knob Interior: -6 point rollcage with side bars, vinyl'd white -cd player -momo monte carlo steering wheel with quick release -boost gauge -water temp gauge -oil pressure gauge -oil temp gauge -wideband -sick shift knob -Bride ZETA II -Bride low seat rail -s14 passenger seat -Carpet Exterior: -OE kouki 180sx kit w/ lip -Kouki wing -Kouki tailights -Rear window lip spoiler -JDM Drop Vented fiberglass hood 320HP Tuned on a Dynapack by Frank @ Garage Boso. Runs perfect. Leak down test and compression test is good. Brand new turbo 0 miles. Built with 6 years experience. Oil changed for every event. Transported with Trailer $10,000 Located in Oakland, CA. Contact: [email protected] Thank you for checking it out. Last edited by tdcxalexander; 06-17-2010 at 11:26 PM.. Reason: new pictures |
#9 |
My bad for not replying, I was engaged with a potential buyer but it ended up not working out because he found another car before he had the chance to check mine out.
Marcus: Yes, very buttery. Thanks ZX88: Not at the moment, but If I part out I will let you know. The car is still for sale, now with a BRAND NEW turbo center section. The turbo rebuild didn't go so well, so I ended up shelling out $500 to buy a new center section! $10,000 Ready to go! |
#17 |
I'd be stoked if someone bought the car!
More detailed pictures are on their way... Open to trades also. Interested in daily drivers, motorcycles, jetskis, and boats. |
#24 |
Bobby, I just e-mailed you. I think we may be able to work something out if I take some parts off.
Thanks for the compliments guys, I'm sad to let her go but it must be done. NEW PICTURES! Great White 180sx - a set on Flickr |
#26 |
No doubt, Frank is a Master Tuner! Highly recommended.
Selling because I'm fresh out of college and trying to focus my energy towards building my career. I currently have a internship that pays me in peanuts, so i'm in need of some living money. I'm liquidating! |
fully built, sr20det |
